I burned the Orin nx 16G module JP5.1 image pack on the 3509 carrier board and had the following problem
* Step 1: Generate flash packages *
Create folder to store images to flash
Generate image for internal storage devices
Generate images to be flashed
ADDITIONAL_DTB_OVERLAY="" /workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/flash.sh --no-flash --sign -c bootloader/t186ref/cfg/flash_t234_qspi.xml p3509-a02+p3767-0000 internal
# L4T BSP Information:
# R35 , REVISION: 2.1
# User release: 0.0
copying emc_fuse_dev_params(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying device_config(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-device-p3767-0000.dts)... done.
copying misc_config(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-misc-p3767-0000.dts)... done.
./tegraflash.py --chip 0x23 --applet "/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --bins "mb2_applet applet_t234.bin" --cmd "dump eeprom cvm cvm.bin; dump custinfo custinfo_out.bin; reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0075 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.0079 ] File rcm_state open failed
[ 0.0081 ] ERROR: failed to read rcm_state
[ 0.0081 ]
[ 0.0085 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0087 ] Assuming zero filled SBK key
[ 0.0083 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[ 0.0116 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[ 0.0161 ] Parsing partition layout
[ 0.0165 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0173 ] Kernel DTB used: None
[ 0.0173 ] WARNING: dce base dtb is not provided
[ 0.0173 ] Parsing partition layout
[ 0.0178 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0184 ] Creating list of images to be signed
[ 0.0188 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[ 0.0192 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0197 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0199 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0225 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0227 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0254 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0255 ] adding BCH for mb2_t234_aligned.bin
[ 0.0271 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0348 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0349 ] adding BCH for mb2_t234_aligned.bin
[ 0.0439 ] Filling MB1 storage info
[ 0.0439 ] Parsing dev params for multi chains
[ 0.0471 ] Generating br-bct
[ 0.0481 ] Updating dev and MSS params in BR BCT
[ 0.0481 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.0487 ] Updating bl info
[ 0.0492 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[ 0.0496 ] WARNING: boot chain is not completed. set to 0
[ 0.0500 ] Generating signatures
[ 0.0505 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0506 ] Assuming zero filled SBK key
[ 0.0574 ] Warning: pub_key.key is not found
[ 0.0572 ] Parsing dev params for multi chains
[ 0.0572 ] Generating br-bct
[ 0.0577 ] Updating dev and MSS params in BR BCT
[ 0.0578 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.0586 ] Updating bl info
[ 0.0594 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.0601 ] WARNING: boot chain is not completed. set to 0
[ 0.0607 ] Get Signed section of bct
[ 0.0615 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 0.0626 ] Signing BCT
[ 0.0631 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0632 ] Assuming zero filled SBK key
[ 0.0657 ] Sha saved in br_bct_BR.sha
[ 0.0660 ] Warning: pub_key.key is not found
[ 0.0656 ] Updating BCT with signature
[ 0.0663 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 0.0670 ] Offset :4608 Len :3584
[ 0.0672 ] Generating SHA2 Hash
[ 0.0677 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 0.0678 ] Assuming zero filled SBK key
[ 0.0698 ] Sha saved in br_bct_BR.sha
[ 0.0696 ] Updating BCT with SHA2 Hash
[ 0.0703 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 0.0708 ] Offset :4608 Len :3584
[ 0.0710 ] Offset :68 Len :8124
[ 0.0711 ] Generating coldboot mb1-bct
[ 0.0716 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.0721 ] MB1-BCT version: 0.9
[ 0.0722 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.0726 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.0728 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.0730 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.0732 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.0734 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.0734 ] ERROR: /misc/vmon/vdd_soc/int/ is not supported
[ 0.0735 ] ERROR: /misc/vmon/vdd_soc/int/ is not supported
[ 0.0735 ] ERROR: /misc/vmon/vdd_cpu/int/ is not supported
[ 0.0735 ]
[ 0.0735 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.0735 ] Added Platform Config 9 data with size :- 100
[ 0.0735 ]
[ 0.0735 ] Updating mb1-bct with firmware information
[ 0.0739 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.0750 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 0.0759 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 0.0764 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 0.0773 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0774 ] Assuming zero filled SBK key
[ 0.0783 ] Warning: pub_key.key is not found
[ 0.0784 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.0792 ] Generating recovery mb1-bct
[ 0.0796 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.0800 ] MB1-BCT version: 0.9
[ 0.0801 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.0804 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.0805 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.0807 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.0809 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.0810 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.0810 ] ERROR: /misc/vmon/vdd_soc/int/ is not supported
[ 0.0810 ] ERROR: /misc/vmon/vdd_cpu/int/ is not supported
[ 0.0811 ]
[ 0.0811 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.0811 ] Added Platform Config 9 data with size :- 100
[ 0.0811 ]
[ 0.0811 ] Updating mb1-bct with firmware information
[ 0.0815 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.0826 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 0.0835 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 0.0838 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 0.0847 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0848 ] Assuming zero filled SBK key
[ 0.0857 ] Warning: pub_key.key is not found
[ 0.0858 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.0865 ] Error: Skip generating mem_bct because sdram_config is not defined
[ 0.0865 ] Copying signatures
[ 0.0869 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.0897 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.0898 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.0898 ] Boot Rom communication
[ 0.0903 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.0907 ] BR_CID: 0x80012344705DD1C11C00000017FE8140
[ 0.1196 ] Sending bct_br
[ 0.1627 ] Sending mb1
[ 0.1634 ] Sending psc_bl1
[ 0.1747 ] Sending bct_mb1
[ 0.1812 ] Boot Rom communication completed
[ 0.1847 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[ 0.1889 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[ 0.1910 ] adding BCH for applet_t234_aligned.bin
[ 0.2146 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.2148 ] Assuming zero filled SBK key
[ 0.2171 ] Warning: pub_key.key is not found
[ 0.2181 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[ 0.2215 ] Sending mb2_applet...
[ 0.2234 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[ 0.2251 ] BL: version 0.28.0.0-t234-54845784-ec016368 last_boot_error: 0
[ 0.3786 ] Sending applet
[ 0.4840 ] completed
[ 0.4865 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.4884 ] MB2 Applet version 01.00.0000
[ 0.6620 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.6626 ] MB2 Applet version 01.00.0000
[ 0.6956 ] Retrieving board information
[ 0.6962 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[ 0.6968 ] MB2 Applet version 01.00.0000
[ 0.7423 ] Saved platform info in chip_info.bin
[ 0.7473 ] Chip minor revision: 1
[ 0.7474 ] Bootrom revision: 0x7
[ 0.7475 ] Ram code: 0x0
[ 0.7475 ] Chip sku: 0xd3
[ 0.7476 ] Chip Sample: prod
[ 0.7483 ] Retrieving EEPROM data
[ 0.7484 ] tegrarcm_v2 --oem platformdetails eeprom cvm /workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[ 0.7490 ] MB2 Applet version 01.00.0000
[ 0.7939 ] Saved platform info in /workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/cvm.bin
[ 0.8289 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.8294 ] MB2 Applet version 01.00.0000
[ 0.8584 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.8591 ] MB2 Applet version 01.00.0000
[ 0.9063 ] Dumping customer Info
[ 0.9071 ] tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
[ 0.9078 ] MB2 Applet version 01.00.0000
[ 0.9553 ] Saved bct in tmp.bct
[ 0.9644 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/custinfo_out.bin
[ 0.9649 ] C[ 0.9651 ] ustomer data saved in /workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/custinfo_out.bin successfully
[ 0.9651 ] Rebooting to recovery mode
[ 0.9656 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[ 0.9989 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.9994 ] MB2 Applet version 01.00.0000
[ 1.0463 ] Booting to recovery mode
[ 1.0481 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
[ 1.0486 ] MB2 Applet version 01.00.0000
Board ID(3767) version(ES1) sku(0000) revision(A.3)
Chip SKU(00:00:00:D3) ramcode(00:00:00:00) fuselevel(fuselevel_production) board_FAB(ES1)
emc_opt_disable_fuse:(0)
Copy /workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/kernel/dtb/tegra234-p3767-0000-p3509-a02.dtb to /workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/kernel/dtb/tegra234-p3767-0000-p3509-a02.dtb.rec
Using UUID 83d070c7-82d4-4c45-b400-16f71d486634 for mounting root APP partition.
copying bctfile(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-p3767-0000-sdram-l4t.dts)... done.
copying pinmux_config(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-pinmux-p3767-hdmi-a03.dtsi)... done.
copying gpioint_config(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-gpioint-p3767-0000.dts)... done.
copying pmic_config(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-pmic-p3767-0000-a02.dts)... done.
copying pmc_config(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-padvoltage-p3767-hdmi-a03.dtsi)... done.
copying deviceprod_config(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-cprod-p3767-0000.dts)... done.
copying prod_config(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-prod-p3767-0000.dts)... done.
copying scr_config(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb2-bct-scr-p3767-0000.dts)... done.
copying wb0sdram(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-p3767-0000-wb0sdram-l4t.dts)... done.
copying bootrom_config(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-reset-p3767-0000.dts)... done.
copying dev_params(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-p3767-0000-l4t.dts)... done.
copying dev_params_b(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct_b-p3767-0000-l4t.dts)... done.
copying mb2bct_cfg(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb2-bct-misc-p3767-0000.dts)... done.
Existing pscfwfile(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/pscfw_t234_prod.bin) reused.
Existing pscbl1file(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/psc_bl1_t234_prod.bin) reused.
Existing mtsmcefile(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/mce_flash_o10_cr_prod.bin) reused.
Existing mb2applet(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/applet_t234.bin) reused.
Existing bootloader(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
copying initrd(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
bl is uefi
Making Boot image... done.
Not signing of boot.img
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/ramdisk_tmp /workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader /workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra
36188 块
gzip: /workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/kernel/Image: not in gzip format
_BASE_KERNEL_VERSION=5.10.104-tegra
54378 块
Making Recovery image...
copying recdtbfile(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/kernel/dtb/tegra234-p3767-0000-p3509-a02.dtb.rec)... done.
记录了20+0 的读入
记录了20+0 的写出
20 bytes copied, 0.000135614 s, 147 kB/s
Existing sosfile(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing tegraboot(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing cpu_bootloader(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing mb2blfile(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing xusbfile(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/xusb_t234_prod.bin) reused.
Existing dcefile(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/display-t234-dce.bin) reused.
Existing nvdecfile(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/nvdec_t234_prod.fw) reused.
Existing psc_rf(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/psc_rf_t234_prod.bin) reused.
Existing mb2_rf(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/mb2rf_t234.bin) reused.
Existing mb1file(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing bpffile(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/bpmp_t234-TE990M-A1_prod.bin) reused.
copying bpfdtbfile(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/t186ref/tegra234-bpmp-3767-0000-a02-3509-a02.dtb)... done.
Existing scefile(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/camera-rtcpu-t234-rce.img) reused.
Existing apefile(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/adsp-fw.bin) reused.
Existing spefile(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/spe_t234.bin) reused.
Existing wb0boot(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/sc7_t234_prod.bin) reused.
Existing tosfile(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/tos-optee_t234.img) reused.
Existing eksfile(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/eks_t234.img) reused.
copying dtbfile(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/kernel/dtb/tegra234-p3767-0000-p3509-a02.dtb)... done.
Copying nv_boot_control.conf to rootfs
populating kernel to rootfs... done.
populating initrd to rootfs... done.
populating kernel_tegra234-p3767-0000-p3509-a02.dtb to rootfs... done.
Making system.img...
Setting "FDT /boot/dtb/kernel_tegra234-p3767-0000-p3509-a02.dtb" successfully in the extlinux.conf...done.
populating rootfs from /workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-populating /boot/extlinux/extlinux.conf ... done.fs ...
Sync'ing system.img ... done.
Converting RAW image to Sparse image... done.
system.img built successfully.
Not signing of kernel-dtb
Existing tbcfile(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/uefi_jetson.bin) reused.
记录了131072+0 的读入
记录了131072+0 的写出
67108864 bytes (67 MB, 64 MiB) copied, 0.141853 s, 473 MB/s
Sync'ing esp.img ... done.
copying tbcdtbfile(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/kernel/dtb/tegra234-p3767-0000-p3509-a02.dtb)... done.
copying cfgfile(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/t186ref/cfg/flash_t234_qspi.xml) to flash.xml... done.
Existing flashapp(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/tegraflash.py) reused.
copying overlay_dtb(/workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/kernel/dtb/L4TConfiguration.dtbo)... done.
./tegraflash.py --bl uefi_jetson_with_dtb.bin --odmdata gbe-uphy-config-8,hsstp-lane-map-3,hsio-uphy-config-0 --overlay_dtb L4TConfiguration.dtbo, --bldtb tegra234-p3767-0000-p3509-a02.dtb --applet mb1_t234_prod.bin --cmd "sign" --cfg flash.xml --chip 0x23 --concat_cpubl_bldtb --cpubl uefi_jetson.bin --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --pinmux_config tegra234-mb1-bct-pinmux-p3767-hdmi-a03.dtsi --gpioint_config tegra234-mb1-bct-gpioint-p3767-0000.dts --pmic_config tegra234-mb1-bct-pmic-p3767-0000-a02.dts --pmc_config tegra234-mb1-bct-padvoltage-p3767-hdmi-a03.dtsi --deviceprod_config tegra234-mb1-bct-cprod-p3767-0000.dts --prod_config tegra234-mb1-bct-prod-p3767-0000.dts --scr_config tegra234-mb2-bct-scr-p3767-0000.dts --wb0sdram_config tegra234-p3767-0000-wb0sdram-l4t.dts --br_cmd_config tegra234-mb1-bct-reset-p3767-0000.dts --dev_params tegra234-br-bct-p3767-0000-l4t.dts,tegra234-br-bct_b-p3767-0000-l4t.dts --mb2bct_cfg tegra234-mb2-bct-misc-p3767-0000.dts --bins "psc_fw pscfw_t234_prod.bin; mts_mce mce_flash_o10_cr_prod.bin; mb2_applet applet_t234.bin; mb2_bootloader mb2_t234.bin; xusb_fw xusb_t234_prod.bin; dce_fw display-t234-dce.bin; nvdec nvdec_t234_prod.fw; bpmp_fw bpmp_t234-TE990M-A1_prod.bin; bpmp_fw_dtb tegra234-bpmp-3767-0000-a02-3509-a02.dtb; sce_fw camera-rtcpu-sce.img; rce_fw camera-rtcpu-t234-rce.img; ape_fw adsp-fw.bin; spe_fw spe_t234.bin; tos tos-optee_t234.img; eks eks_t234.img" --sdram_config tegra234-p3767-0000-sdram-l4t.dts --cust_info custinfo_out.bin --secondary_gpt_backup --bct_backup --boot_chain A
saving flash command in /workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/flash_win.bat
*** Sign and generate flashing ready partition images... ***
version 1.0.0
[ 0.0094 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0094 ] Assuming zero filled SBK key
[ 0.0090 ] Parsing partition layout
[ 0.0099 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.0128 ] Change tegra234-bpmp-3767-0000-a02-3509-a02.dtb to tegra234-bpmp-3767-0000-a02-3509-a02_with_odm.dtb
[ 0.0129 ] Change tegra234-bpmp-3767-0000-a02-3509-a02.dtb to tegra234-bpmp-3767-0000-a02-3509-a02_with_odm.dtb
[ 0.0308 ] /usr/bin/python3 dtbcheck.py -c t234 -o tegra234-bpmp-3767-0000-a02-3509-a02_with_odm.dtb tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_tmp.dtb
[ 0.2988 ] Concatenating L4TConfiguration.dtbo to tegra234-p3767-0000-p3509-a02_with_odm.dtb
[ 0.2989 ] Concatenating bl dtb to cpubl binary
[ 0.3006 ] MB2 binary: mb2_t234.bin
[ 0.3006 ] Pre-processing mb2bct config: tegra234-mb2-bct-misc-p3767-0000.dts
[ 0.3240 ] Pre-processing mb2bct config: tegra234-mb2-bct-scr-p3767-0000.dts
[ 0.6456 ] Generating coldboot mb2-bct
[ 0.6457 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct.cfg --mb2bctcfg tegra234-mb2-bct-misc-p3767-0000_cpp.dtb --scr tegra234-mb2-bct-scr-p3767-0000_cpp.dtb
[ 0.6462 ] WARNING: unknown property 'tfc_version'
[ 0.6480 ] WARNING: unknown property 'addr_header_version'
[ 0.6549 ] Updating mb2-bct with storage information
[ 0.6555 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct_MB2.bct --updatestorageinfo flash.xml.bin
[ 0.6563 ] Concatenating mb2-bct to mb2 binary
[ 0.6563 ] mb2_bin_file = mb2_t234.bin
[ 0.6563 ] mb2_bct_file = mb2_cold_boot_bct_MB2.bct
[ 0.6587 ] DCE binary: display-t234-dce.bin
[ 0.6588 ] Kernel DTB used: tegra234-p3767-0000-p3509-a02_with_odm.dtb
[ 0.6588 ] Concatenating kernel-dtb to dce-fw binary
[ 0.6588 ] dce_bin = display-t234-dce.bin
[ 0.6588 ] kernel_dtb = tegra234-p3767-0000-p3509-a02_with_odm.dtb
[ 0.6588 ] dce_with_dtb = display-t234-dce_with_tegra234-p3767-0000-p3509-a02_with_odm.bin
[ 0.6661 ] Update display-t234-dce_with_tegra234-p3767-0000-p3509-a02_with_odm.bin to dce_fw partitions
[ 0.6676 ] Parsing partition layout
[ 0.6684 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.6694 ] Creating list of images to be signed
[ 0.6704 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 0.6710 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.6718 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.6720 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.6754 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.6756 ] Header already present for nvdec_t234_prod_aligned.fw
[ 0.6775 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[ 0.6809 ] adding BCH for xusb_t234_prod_aligned.bin
[ 0.6894 ] Header already present for bpmp_t234-TE990M-A1_prod_aligned.bin
[ 0.6945 ] adding BCH for tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_aligned.dtb
[ 0.7045 ] Header already present for pscfw_t234_prod_aligned.bin
[ 0.7076 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[ 0.7117 ] Header already present for sc7_t234_prod.bin
[ 0.7139 ] Header already present for psc_rf_t234_prod_aligned.bin
[ 0.7159 ] adding BCH for mb2rf_t234_aligned.bin
[ 0.7174 ] adding BCH for uefi_jetson_with_dtb_aligned.bin
[ 0.7234 ] adding BCH for tos-optee_t234_aligned.img
[ 0.7874 ] adding BCH for eks_t234_aligned.img
[ 0.8081 ] INFO: compressing display-t234-dce_with_tegra234-p3767-0000-p3509-a02_with_odm_aligned.bin
[ 0.9102 ] INFO: complete compression, display-t234-dce_with_tegra234-p3767-0000-p3509-a02_with_odm_aligned.bin, ratio = 7%
[ 0.9219 ] adding BCH for display-t234-dce_with_tegra234-p3767-0000-p3509-a02_with_odm_aligned_blob_w_bin_aligned.bin
[ 0.9323 ] adding BCH for spe_t234_aligned.bin
[ 0.9434 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[ 0.9495 ] adding BCH for adsp-fw_aligned.bin
[ 0.9606 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.9689 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.9690 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.9719 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.9720 ] Header already present for nvdec_t234_prod_aligned.fw
[ 0.9734 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[ 0.9768 ] adding BCH for xusb_t234_prod_aligned.bin
[ 0.9851 ] Header already present for bpmp_t234-TE990M-A1_prod_aligned.bin
[ 0.9896 ] adding BCH for tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_aligned.dtb
[ 1.0000 ] Header already present for pscfw_t234_prod_aligned.bin
[ 1.0031 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[ 1.0069 ] Header already present for sc7_t234_prod.bin
[ 1.0088 ] Header already present for psc_rf_t234_prod_aligned.bin
[ 1.0106 ] adding BCH for mb2rf_t234_aligned.bin
[ 1.0119 ] adding BCH for uefi_jetson_with_dtb_aligned.bin
[ 1.0183 ] adding BCH for tos-optee_t234_aligned.img
[ 1.0805 ] adding BCH for eks_t234_aligned.img
[ 1.1014 ] INFO: compressing display-t234-dce_with_tegra234-p3767-0000-p3509-a02_with_odm_aligned.bin
[ 1.2058 ] INFO: complete compression, display-t234-dce_with_tegra234-p3767-0000-p3509-a02_with_odm_aligned.bin, ratio = 7%
[ 1.2176 ] adding BCH for display-t234-dce_with_tegra234-p3767-0000-p3509-a02_with_odm_aligned_blob_w_bin_aligned.bin
[ 1.2277 ] adding BCH for spe_t234_aligned.bin
[ 1.2351 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[ 1.2408 ] adding BCH for adsp-fw_aligned.bin
[ 1.2593 ] Filling MB1 storage info
[ 1.2593 ] Parsing dev params for multi chains
[ 1.2633 ] Generating br-bct
[ 2.2210 ] Updating dev and MSS params in BR BCT
[ 2.2210 ] tegrabct_v2 --dev_param tegra234-br-bct-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 2.2818 ] Updating bl info
[ 2.2824 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[ 2.2865 ] Generating br-bct
[ 2.2871 ] Updating dev and MSS params in BR BCT
[ 2.2871 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 2.3479 ] Updating bl info
[ 2.3485 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[ 2.3494 ] Generating BCT backup image
[ 2.3494 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[ 2.3500 ] 记录了32768+0 的读入
[ 2.3713 ] 记录了32768+0 的写出
[ 2.3713 ] 32768 bytes (33 kB, 32 KiB) copied, 0.0210177 s, 1.6 MB/s
[ 2.3713 ]
[ 2.3714 ] Concatenating BCT for chain A to bct_backup.img
[ 2.3714 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[ 2.3719 ] 记录了8192+0 的读入
[ 2.3761 ] 记录了8192+0 的写出
[ 2.3761 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.00401928 s, 2.0 MB/s
[ 2.3761 ]
[ 2.3762 ] Concatenating BCT for chain B to bct_backup.img
[ 2.3762 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[ 2.3767 ] 记录了8192+0 的读入
[ 2.3809 ] 记录了8192+0 的写出
[ 2.3809 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.00401101 s, 2.0 MB/s
[ 2.3809 ]
[ 2.3809 ] Generating signatures
[ 2.3816 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 2.3817 ] Assuming zero filled SBK key
[ 2.4731 ] Warning: pub_key.key is not found
[ 2.4741 ] Pre-processing config: tegra234-mb1-bct-reset-p3767-0000.dts
[ 2.4775 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[ 2.4810 ] Pre-processing config: tegra234-mb1-bct-cprod-p3767-0000.dts
[ 2.4840 ] Pre-processing config: tegra234-mb1-bct-gpioint-p3767-0000.dts
[ 2.4877 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[ 2.4937 ] Pre-processing config: tegra234-mb1-bct-pinmux-p3767-hdmi-a03.dtsi
Error: Return value 1
Command cpp -nostdinc -x assembler-with-cpp -D IN_DTS_CONTEXT tegra234-mb1-bct-pinmux-p3767-hdmi-a03.dtsi tegra234-mb1-bct-pinmux-p3767-hdmi-a03_cpp.dts
Error: /workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/bootloader/signed/flash.idx is not found
Error: failed to relocate images to /workspace/NVIDIA_Sources/Jetson-Orin-NX/Orin-NX-JP_51_BSP_EA_V35.2.1/working/Linux_for_Tegra/tools/kernel_flash/images
Cleaning up...
The command I use is:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" --showlogs --network usb0 p3509-a02+p3767-0000 internal
