Jetson Orin NX 8GB stops during bootloader stage after previously working normally
Hello NVIDIA team,
We are using a Jetson Orin NX 8GB module with our custom carrier board for a mass-produced product.
Recently, one of our customer reported that one unit could no longer boot. We collected the unit from the customer and checked the serial console log. According to the log, the boot process appears to stop during the bootloader stage.
The customer reported that the unit had been working normally until shortly before the issue occurred.
The unit had also passed both our factory outgoing inspection and the customer’s incoming inspection.
For this reason, we currently do not believe this is an initial hardware defect. However, we would like to understand what the bootloader error indicates and how we should proceed with the investigation.
Could you please help us clarify the following points?
  1. What does the error shown in the log mean?
  2. Are there any known issues or similar cases related to this bootloader behavior on Jetson Orin NX 8GB?
  3. Is there any recovery procedure or workaround for this condition?
  4. What additional information, logs, or registers should we collect to help identify the root cause?
  5. Are there any checks we should perform on the custom carrier board side, such as power sequence, reset signals, boot device, or storage integrity?
Current information:
  1. Module: Jetson Orin NX 8GB
  2. Carrier board: Custom carrier board
  3. L4T 36.4.4
We would appreciate your advice on the possible cause, meaning of the error log, and recommended next steps for recovery and root cause analysis.
Thank you.
The relevant log is shown below:
\00\FF\E2
[0000.064] I> MB1 (version: 1.4.0.2-t234-54845784-08a4de08)
[0000.070] I> t234-A01-1-Silicon (0x12347) Prod
[0000.074] I> Boot-mode : Coldboot
[0000.077] I> Entry timestamp: 0x00000000
[0000.081] I> last_boot_error: 0x0
[0000.084] I> BR-BCT: preprod_dev_sign: 0
[0000.088] I> rst_source: 0x0, rst_level: 0x0
[0000.092] I> Task: SE error check
[0000.095] I> Task: Bootchain select WAR set
[0000.099] I> Task: Enable SLCG
[0000.102] I> Task: CRC check
[0000.105] I> Task: Initialize MB2 params
[0000.109] I> MB2-params @ 0x40060000
[0000.113] I> Task: Crypto init
[0000.116] I> Task: Perform MB1 KAT tests
[0000.120] I> Task: NVRNG health check
[0000.123] I> NVRNG: Health check success
[0000.127] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.133] I> Task: Enabling and initialization of Bandwidth limiter
[0000.139] I> No request to configure MBWT settings for any PC!
[0000.145] I> Task: Secure debug controls
[0000.149] I> Task: strap war set
[0000.152] I> Task: Initialize SOC Therm
[0000.155] I> Task: Program NV master stream id
[0000.160] I> Task: Verify boot mode
[0000.165] I> Task: Alias fuses
[0000.169] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.176] I> Task: Print SKU type
[0000.179] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c8
[0000.184] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0000.189] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0000.193] I> FUSE_OPT_DLA_DISABLE = 0x00000002
[0000.197] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.201] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.206] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.210] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0000.215] I> FUSE_OPT_EMC_DISABLE = 0x0000000c
[0000.219] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.223] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.227] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.231] I> FUSE_SKU_INFO_0 = 0xd4
[0000.235] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.239] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.242] I> SKU: Prod
[0000.245] I> Task: Boost clocks
[0000.248] I> Initializing NAFLL for BPMP_CPU_NIC.
[0000.253] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0000.258] I> BPMP NAFLL lock success.
[0000.262] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0000.266] I> Initializing PLLC2 for AXI_CBB.
[0000.270] I> AXI_CBB : src = 35, divisor = 0
[0000.274] I> Task: Voltage monitor
[0000.278] I> VMON: Vmon re-calibration and fine tuning done
[0000.283] I> Task: UPHY init
[0000.288] I> HSIO UPHY init done
[0000.291] W> Skipping GBE UPHY config
[0000.295] I> Task: Boot device init
[0000.298] I> Boot_device: QSPI_FLASH instance: 0
[0000.303] I> Qspi clock source : pllc_out0
[0000.307] I> QSPI Flash: Macronix 64MB
[0000.310] I> QSPI-0l initialized successfully
[0000.315] I> Task: TSC init
[0000.317] I> Task: Load membct
[0000.320] I> RAM_CODE 0x4000431
[0000.323] I> Loading MEMBCT
[0000.326] I> Slot: 1
[0000.328] I> Binary[0] block-66816 (partition size: 0x40000)
[0000.334] I> Binary name: MEM-BCT-0
[0000.337] I> Size of crypto header is 8192
[0000.341] I> Size of crypto header is 8192
[0000.345] I> strt_pg_num(66816) num_of_pgs(16) read_buf(0x40050000)
[0000.351] I> BCH of MEM-BCT-0 read from storage
[0000.355] I> BCH address is : 0x40050000
[0000.359] I> MEM-BCT-0 header integrity check is success
[0000.365] I> Binary magic in BCH component 0 is MEM0
[0000.369] I> component binary type is 0
[0000.373] I> strt_pg_num(66832) num_of_pgs(115) read_buf(0x40040000)
[0000.380] I> MEM-BCT-0 binary is read from storage
[0000.385] I> MEM-BCT-0 binary integrity check is success
[0000.390] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.396] I> RAM_CODE 0x4000431
[0000.402] I> RAM_CODE 0x4000431
[0000.406] I> Task: Load Page retirement list
[0000.410] I> Task: SDRAM params override
[0000.414] I> Task: Save mem-bct info
[0000.417] I> Task: Carveout allocate
[0000.421] I> RCM blob carveout will not be allocated
[0000.425] I> Update CCPLEX IST carveout from MB1-BCT
[0000.430] I> ECC region[0]: Start:0x0, End:0x0
[0000.434] I> ECC region[1]: Start:0x0, End:0x0
[0000.439] I> ECC region[2]: Start:0x0, End:0x0
[0000.443] I> ECC region[3]: Start:0x0, End:0x0
[0000.447] I> ECC region[4]: Start:0x0, End:0x0
[0000.452] I> Non-ECC region[0]: Start:0x80000000, End:0x280000000
[0000.458] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.462] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.467] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.471] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.482] I> allocated(CO:43) base:0xbe000000 size:0x4000000 align: 0x200000
[0000.489] I> allocated(CO:39) base:0x27de00000 size:0x2200000 align: 0x10000
[0000.496] I> allocated(CO:20) base:0x27a000000 size:0x2000000 align: 0x2000000
[0000.503] I> allocated(CO:24) base:0x278000000 size:0x2000000 align: 0x2000000
[0000.510] I> allocated(CO:28) base:0x276000000 size:0x2000000 align: 0x2000000
[0000.517] I> allocated(CO:22) base:0x27c000000 size:0x1000000 align: 0x1000000
[0000.524] I> allocated(CO:35) base:0x275000000 size:0x1000000 align: 0x100000
[0000.531] I> allocated(CO:02) base:0x27d000000 size:0x800000 align: 0x800000
[0000.538] I> allocated(CO:03) base:0x274800000 size:0x800000 align: 0x800000
[0000.545] I> allocated(CO:06) base:0x274000000 size:0x800000 align: 0x800000
[0000.552] I> allocated(CO:56) base:0x273800000 size:0x800000 align: 0x200000
[0000.559] I> allocated(CO:07) base:0x27d800000 size:0x400000 align: 0x400000
[0000.566] I> allocated(CO:33) base:0x273400000 size:0x400000 align: 0x200000
[0000.573] I> allocated(CO:19) base:0x273180000 size:0x280000 align: 0x10000
[0000.580] I> allocated(CO:23) base:0x27dc00000 size:0x200000 align: 0x200000
[0000.587] I> allocated(CO:01) base:0x273000000 size:0x100000 align: 0x100000
[0000.594] I> allocated(CO:05) base:0x272f00000 size:0x100000 align: 0x100000
[0000.601] I> allocated(CO:08) base:0x272e00000 size:0x100000 align: 0x100000
[0000.608] I> allocated(CO:09) base:0x272d00000 size:0x100000 align: 0x100000
[0000.615] I> allocated(CO:12) base:0x272c00000 size:0x100000 align: 0x100000
[0000.622] I> allocated(CO:15) base:0x272b00000 size:0x100000 align: 0x100000
[0000.629] I> allocated(CO:17) base:0x272a00000 size:0x100000 align: 0x100000
[0000.636] I> allocated(CO:27) base:0x272900000 size:0x100000 align: 0x100000
[0000.642] I> allocated(CO:42) base:0x272800000 size:0x100000 align: 0x100000
[0000.649] I> allocated(CO:54) base:0x273100000 size:0x80000 align: 0x80000
[0000.656] I> allocated(CO:34) base:0x2727f0000 size:0x10000 align: 0x10000
[0000.663] I> allocated(CO:72) base:0x2725f0000 size:0x200000 align: 0x10000
[0000.670] I> allocated(CO:47) base:0x272000000 size:0x400000 align: 0x200000
[0000.677] I> allocated(CO:50) base:0x271e00000 size:0x200000 align: 0x100000
[0000.684] I> allocated(CO:48) base:0x2725d0000 size:0x20000 align: 0x10000
[0000.690] I> allocated(CO:69) base:0x2725b0000 size:0x20000 align: 0x10000
[0000.697] I> allocated(CO:49) base:0x2725a0000 size:0x10000 align: 0x10000
[0000.704] I> NSDRAM base: 0x80000000, end: 0x2725f0000, size: 0x1f25f0000
[0000.711] I> Task: Thermal check
[0000.714] I> Using min_chip_limit as min_tmon_limit
[0000.718] I> Using max_chip_limit as max_tmon_limit
[0000.723] I> BCT max_tmon_limit = 105
[0000.727] I> BCT min_tmon_limit = -28
[0000.730] I> BCT max_tmon_limit = 105
[0000.734] I> BCT min_tmon_limit = -28
[0000.737] I> SKU specific max_chip_limit = 105
[0000.741] I> SKU specific min_chip_limit = -28
[0000.746] I> BCT max_chip_limit = 105
[0000.749] I> BCT min_chip_limit = -28
[0000.753] I> enable_soctherm_polling = 0
[0000.756] I> max temp read = 28
[0000.759] I> min temp read = 27
[0000.762] I> Enabling thermtrip
[0000.765] I> Task: Update FSI SCR with thermal fuse data
[0000.770] I> Task: Enable WDT 5th expiry
[0000.774] I> Task: I2C register
[0000.777] I> Task: Set I2C bus freq
[0000.781] I> Task: Reset FSI
[0000.783] I> Task: Pinmux init
[0000.786] I> skipped mmio_addr = 0x9240008
[0000.790] I> skipped mmio_addr = 0x9240000
[0000.794] I> skipped mmio_addr = 0x9240010
[0000.798] I> skipped mmio_addr = 0x9240018
[0000.802] I> skipped mmio_addr = 0x9240020
[0000.806] I> skipped mmio_addr = 0x9240030
[0000.810] I> skipped mmio_addr = 0x9240028
[0000.814] I> skipped mmio_addr = 0x9240038
[0000.818] I> skipped mmio_addr = 0x9240040
[0000.822] I> skipped mmio_addr = 0x9240048
[0000.826] I> skipped mmio_addr = 0x9241000
[0000.830] I> skipped mmio_addr = 0x9241008
[0000.834] I> skipped mmio_addr = 0x9241010
[0000.838] I> skipped mmio_addr = 0x9241018
[0000.842] I> skipped mmio_addr = 0x9241020
[0000.846] I> skipped mmio_addr = 0x9241028
[0000.849] I> skipped mmio_addr = 0x9241030
[0000.853] I> skipped mmio_addr = 0x9241038
[0000.857] I> skipped mmio_addr = 0x9241040
[0000.861] I> skipped mmio_addr = 0x9242000
[0000.865] I> skipped mmio_addr = 0x9242008
[0000.869] I> Task: Prod config init
[0000.873] I> Task: Pad voltage init
[0000.876] I> Task: Prod init
[0000.879] I> Task: Program rst req config reg
[0000.883] I> Task: Common rail init
[0000.886] I> DONE: Thermal config
[0000.890] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.898] I> DONE: SOC rail config
[0000.902] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.908] I> DONE: MEMIO rail config
[0000.912] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0000.918] I> DONE: GPU rail info
[0000.922] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0000.928] I> DONE: CV rail info
[0000.931] I> Task: Mem clock src
[0000.934] I> Task: Misc. board config
[0000.938] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.944] I> Task: SDRAM init
[0000.946] I> MemoryType: 4 MemBctRevision: 1
[0000.953] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 1
[0000.961] I> MSS CAR: Init PLLM
[0000.964] I> MSS CAR: Init PLLHUB
[0000.968] I> Encryption: MTS: en, TX: en, VPR: en, GSC: en
[0000.980] I> SDRAM initialized!
[0000.983] I> SDRAM Size in Total 0x200000000
[0000.987] I> Task: Dram Ecc scrub
[0000.990] I> Task: DRAM alias check
[0000.997] I> Task: Program NSDRAM carveout
[0001.000] I> NSDRAM carveout encryption is enabled
[0001.005] I> Program NSDRAM carveout
[0001.009] I> Task: Register checker
[0001.012] I> Task: Enable clock-mon
[0001.016] I> FMON: Fmon re-programming done
[0001.020] I> Task: Mapper init
[0001.023] I> Task: SC7 Context Init
[0001.026] I> Task: CCPLEX IST init
[0001.030] I> Task: CPU WP0
[0001.032] I> Loading MCE
[0001.035] I> Slot: 1
[0001.037] I> Binary[8] block-85760 (partition size: 0x80000)
[0001.042] I> Binary name: MCE
[0001.045] I> Size of crypto header is 8192
[0001.049] I> Size of crypto header is 8192
[0001.053] I> strt_pg_num(85760) num_of_pgs(16) read_buf(0x4003e000)
[0001.059] I> BCH of MCE read from storage
[0001.063] I> BCH address is : 0x4003e000
[0001.067] I> MCE header integrity check is success
[0001.072] I> Binary magic in BCH component 0 is MTSM
[0001.076] I> component binary type is 8
[0001.080] I> Size of crypto header is 8192
[0001.084] I> strt_pg_num(85776) num_of_pgs(350) read_buf(0x40000000)
[0001.092] I> MCE binary is read from storage
[0001.097] I> MCE binary integrity check is success
[0001.101] I> Binary MCE loaded successfully at 0x40000000 (0x2baf0)
[0001.108] I> Size of crypto header is 8192
[0001.119] I> Size of crypto header is 8192
[0001.123] I> Sending WP0 mailbox command to PSC
[0001.132] I> Task: XUSB Powergate
[0001.135] I> Skipping powergate XUSB.
[0001.138] I> Task: MB1 fixed firewalls
[0001.145] W> Firewall readback mismatch
[0001.150] I> Task: Load bpmp-fw
[0001.153] I> Slot: 1
[0001.155] I> Binary[15] block-72960 (partition size: 0x180000)
[0001.160] I> Binary name: BPMP_FW
[0001.163] I> Size of crypto header is 8192
[0001.167] I> Size of crypto header is 8192
[0001.171] I> strt_pg_num(72960) num_of_pgs(16) read_buf(0x807fe000)
[0001.178] I> BCH of BPMP_FW read from storage
[0001.182] I> BCH address is : 0x807fe000
[0001.186] C> LOADER: Could not read binary 15.
[0001.190] C> Task 0x3d failed (err: 0x8228e18)
[0001.194] E> Top caller module: BPMP_FW, error module: LOADER, reason: 0x18, aux_info: 0x8e
[0001.203] C> Boot Info Table status dump :
0111111100111000111111111111111111111111111110111011111101111
\00\FF\E2
[0000.069] I> t234-A01-1-Silicon (0x12347) Prod
[0000.080] I> last_boot_error: 0x8228e18
[0000.088] I> rst_source: 0xb, rst_level: 0x1
[0000.148] I> Task: strap war set
[0000.151] I> Task: Initialize SOC Therm
[0000.188] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0000.214] I> FUSE_OPT_EMC_DISABLE = 0x0000000c
[0000.234] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.244] I> Task: Boost clocks
[0000.247] I> Initializing NAFLL for BPMP_CPU_NIC.
[0000.261] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0000.294] I> Task: Boot device init
[0000.302] I> Qspi clock source : pllc_out0
[0000.306] I> QSPI Flash: Macronix 64MB
[0000.314] I> Task: TSC init
[0000.326] I> Slot: 0
[0000.328] I> Binary[0] block-3840 (partition size: 0x40000)
[0000.333] I> Binary name: MEM-BCT-0
[0000.345] I> strt_pg_num(3840) num_of_pgs(16) read_buf(0x40050000)
[0000.364] I> Binary magic in BCH component 0 is MEM0
[0000.373] I> strt_pg_num(3856) num_of_pgs(115) read_buf(0x40040000)
[0000.384] I> MEM-BCT-0 binary integrity check is success
[0000.401] I> RAM_CODE 0x4000431
[0000.405] I> Task: Load Page retirement list
[0000.413] I> Task: Save mem-bct info
[0000.420] I> RCM blob carveout will not be allocated
[0000.438] I> ECC region[2]: Start:0x0, End:0x0
[0000.451] I> Non-ECC region[0]: Start:0x80000000, End:0x280000000
[0000.457] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.466] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.593] I> allocated(CO:05) base:0x272f00000 size:0x100000 align: 0x100000
[0000.600] I> allocated(CO:08) base:0x272e00000 size:0x100000 align: 0x100000
[0000.607] I> allocated(CO:09) base:0x272d00000 size:0x100000 align: 0x100000
[0000.614] I> allocated(CO:12) base:0x272c00000 size:0x100000 align: 0x100000
[0000.621] I> allocated(CO:15) base:0x272b00000 size:0x100000 align: 0x100000
[0000.628] I> allocated(CO:17) base:0x272a00000 size:0x100000 align: 0x100000
[0000.635] I> allocated(CO:27) base:0x272900000 size:0x100000 align: 0x100000
[0000.669] I> allocated(CO:47) base:0x272000000 size:0x400000 align: 0x200000
[0000.676] I> allocated(CO:50) base:0x271e00000 size:0x200000 align: 0x100000
[0000.683] I> allocated(CO:48) base:0x2725d0000 size:0x20000 align: 0x10000
[0000.710] I> Task: Thermal check
[0000.713] I> Using min_chip_limit as min_tmon_limit
[0000.726] I> BCT min_tmon_limit = -28
[0000.733] I> BCT min_tmon_limit = -28
[0000.745] I> BCT max_chip_limit = 105
[0000.752] I> enable_soctherm_polling = 0
[0000.780] I> Task: Reset FSI
[0000.825] I> skipped mmio_addr = 0x9241000
[0000.829] I> skipped mmio_addr = 0x9241008
[0000.833] I> skipped mmio_addr = 0x9241010
[0000.837] I> skipped mmio_addr = 0x9241018
[0000.841] I> skipped mmio_addr = 0x9241020
[0000.845] I> skipped mmio_addr = 0x9241028
[0000.872] I> Task: Pad voltage init
[0000.875] I> Task: Prod init
[0000.878] I> Task: Program rst req config reg
[0000.882] I> Task: Common rail init
[0000.909] I> DONE: MEMIO rail config
[0000.913] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0000.919] I> DONE: GPU rail info
[0000.947] I> MemoryType: 4 MemBctRevision: 1
[0001.001] I> NSDRAM carveout encryption is enabled
[0001.027] I> Task: CCPLEX IST init
[0001.035] I> Slot: 0
[0001.037] I> Binary[8] block-22784 (partition size: 0x80000)
[0001.053] I> strt_pg_num(22784) num_of_pgs(16) read_buf(0x4003e000)
[0001.077] I> component binary type is 8
[0001.084] I> strt_pg_num(22800) num_of_pgs(350) read_buf(0x40000000)
[0001.102] I> Binary MCE loaded successfully at 0x40000000 (0x2baf0)
[0001.153] I> Slot: 0
[0001.155] I> Binary[15] block-9984 (partition size: 0x180000)
[0001.171] I> strt_pg_num(9984) num_of_pgs(16) read_buf(0x807fe000)
[0001.202] C> Boot Info Table status dump :
— 🤖 This is an automated AI response. I’m here to help, but please verify important details! —
The error message “LOADER: Could not read binary 15” indicates that the bootloader is unable to read the BPMP_FW binary from storage. This error is likely caused by a problem with the storage device or the BPMP_FW binary itself.
Based on the provided log, it appears that the bootloader is trying to read the BPMP_FW binary from the QSPI flash storage, but it is failing to do so. The error message “C> LOADER: Could not read binary 15” is followed by a task failure message “C> Task 0x3d failed (err: 0x8228e18)” and an error message “E> Top caller module: BPMP_FW, error module: LOADER, reason: 0x18, aux_info: 0x8e”.
To troubleshoot this issue, you can try the following steps:
  1. Check the storage device: Verify that the QSPI flash storage is properly connected and configured. Check for any signs of physical damage or wear.
  2. Check the BPMP_FW binary: Verify that the BPMP_FW binary is correctly programmed and not corrupted. You can try reprogramming the binary or checking its integrity.
  3. Check the bootloader configuration: Verify that the bootloader is correctly configured to read the BPMP_FW binary from the QSPI flash storage. Check the bootloader’s configuration files and settings.
  4. Try a different storage device: If possible, try using a different storage device to see if the issue is specific to the QSPI flash storage.
If none of these steps resolve the issue, it may be necessary to seek further assistance from NVIDIA support or a qualified engineer.
In terms of additional information, logs, or registers that should be collected to help identify the root cause, you may want to consider collecting the following:
  • The complete bootloader log, including any error messages or warnings.
  • The BPMP_FW binary itself, to verify its integrity and correctness.
  • The storage device’s configuration and settings, to verify that it is properly configured.
  • Any relevant system or hardware registers, to verify that the system is in a correct state.
It’s also recommended to check the custom carrier board side, such as power sequence, reset signals, boot device, or storage integrity, to ensure that they are not causing the issue.
It’s worth noting that the error message “LOADER: Could not read binary 15” is a generic error message, and it may not provide enough information to determine the root cause of the issue. Further investigation and troubleshooting may be necessary to determine the root cause and resolve the issue.
— We support team will also look into your issue to have further suggestions soon. please stay tuned. —
Are you still able to reflash your board with this SOM?
Hello WayneWWW.
We have not tried reflashing the SOM yet. Since this issue has occurred on only one unit so far, we would like to preserve its current state for root cause analysis.
If reflashing succeeds and the unit recovers, we are concerned it may make further investigation difficult.
Do you have NV devkit that can test ?
Yes, I have an Orin Nano DevKit . What kind of test would you like me to perform?
I also connected the problematic SoM to the Orin Nano DevKit and checked the UART log. The same issue occurred there as well.
Try to reflash the SOM on NV devkit first.
If even the reflashing is not work on devkit, then SOM might have problem.
Staying in the situation there might not help because the crash point is in MB1/MB2. What could be debugged there is limited. Need to check if you could reproduce the issue with some method or not.
Could you please explain what this error log means?
In particular, I would like to understand what the sequence of 0 and 1 represents. Is this a kind of bitmap or status flags? If so, what does each bit correspond to?
I am planning to try reflashing the software later, but before doing that, I would like to understand the meaning of this message.
Any insights would be greatly appreciated.
There is no meaning in above 0/1.
The key problem here is below.
Binary 15 here is the bpmp fw.
Trying to load bpmp fw failed and the reason is unknown. Seems corrupted. 0x18 means VERIFY_FAILED.
As I already told, interpreting those 0/1 won’t give you an answer to anything. What you need to try here is reflash the board first. See if even reflash and reboot in this case also leads to same problem.
If issue is gone, you need to figure out what did you do previously to cause this issue so that we can do further check.
