Jetson Orin NX CAN bus working at Listen-only/Silent mode
Hi All
Our customer need CAN bus working at Listen-only/Silent mode by BSP(DTS/driver etc…)/HW level.
(S/W level “sudo ip link set can0 type can bitrate 500000 listen-only on” was rejected by customer…)
We think about cut-off Jetson module CAN_TX pin as follows.
But no idea it correct/workable or not..
CAN transceiver: NXP TJA1043T
We consider control it for listen-mode also.
Any help would be greatly appreciated, thank all.
Hi nekochang,
Cutting off the Orin/Jetson CAN_TX pin is not our recommended approach for Listen-only/Silent mode.
For TJA1043/TJA1043T, the preferred HW-level method is to control the transceiver mode through STB_N and EN; Listen-only is selected by STB_N = High and EN = Low, which keeps the receiver active and disables the transmitter.
On Jetson, listen-only support exists in the CAN driver path, but this is typically not a DTS-only setting.
So our recommendation is to implement silent mode through transceiver mode control and validate it on the target board.
Hi @KevinFFF
Thanks you, I will use your TJA1043 method.
For this project, STB_N and EN pin connected to i2c GPIO expanded PCA6416APW and no driver occupy, therefore control both easily by i2cset
And your written about
If possible, can you teach me how to enable it?
Because in other project, H/W same above but STB_N and EN pin handle by CAN driver as follows
                mttcan@c310000 {
                        status = "okay";
+                       gpio_can_en-gpios = <&expand_gpio 1 GPIO_ACTIVE_LOW>;           /* Reference to the I2C GPIO expander @ 0-0020 (Pin 5(P0_1) -> CAN0_EN, Active High) */
+                       gpio_can_stb-gpios = <&expand_gpio 2 GPIO_ACTIVE_LOW>;          /* Reference to the I2C GPIO expander @ 0-0020 (Pin 6(P0_2) -> CAN0_STB_B, Active High) */
So can’t control both as above project.
Thanks you very much.
Thanks for the update.
Yes, Jetson listen-only is enabled at the CAN controller level, not as a dedicated DTS property.
However, if gpio_can_stb and gpio_can_en are already owned by the mttcan driver, listen-only on will not automatically switch the TJA1043/TJA1043T transceiver into hardware listen-only mode.
So in this case, if you need true transceiver silent mode as well, you would need either to control STB_N/EN outside the driver, or modify the driver behavior for listen-only mode.
Hi @KevinFFF
Thanks your answer.
Follows your answer, interest code found @ m_ttcan_linux.c as follows
mttcan_controller_config()
        } else if (priv->can.ctrlmode & CAN_CTRLMODE_LISTENONLY) {
                /* silent mode : bus-monitoring mode */
                ttcan_set_bus_monitoring_mode(priv->ttcan, true);
ttcan_set_bus_monitoring_mode() control register directly.
And Google AI written CAN_CTRLMODE_LISTENONLY using for user-space code.
I have a idea…
  • Create DTS property like monitoring-mode,
  • If it set,
    1.Either call ttcan_set_bus_monitoring_mode() to set listen mode and reject enable/disable requirement from user-space.
    2 Or control STB_N/EN pin directly.
Your idea is possible, but it requires a custom driver/BSP change, not DTS only.
mttcan already supports CAN_CTRLMODE_LISTENONLY for controller silent mode.
But if you need true TJA1043/TJA1043T hardware silent mode, I would also recommend controlling STB_N/EN to the proper listen-only state.
Hi @KevinFFF
I got it, thank your solution.
