When using the Jetson Orin NX core board + our self-designed bottom board, we found that the NX failed to start at a low temperature of -40°C. The final print information shows that the NX is checking the SOC temperature. May I ask if the user can customize the upper and lower temperature limits for this temperature check? Is this startup failure related to this temperature check?
jetson orin nx start.log (22.9 KB)
You should fix your test case… but not fix this problem.
Read the spec before you make your testcase…
