Hello!
I’m bringing up a custom MIPI CSI-2 camera sensor on a Jetson Orin NX running kernel 5.15.148-tegra. The sensor is an RS300 thermal camera connected through a MIPI expansion/breakout setup.
The driver probes and binds successfully, the media graph is enabled, and the sensor driver reports that streaming starts successfully. However, I never receive frames. The VI times out repeatedly, and RTCPU tracing shows PHY_INTR on phy:0 cil:0.
Hardware / setup:
Platform: Jetson Orin NX
Kernel:
5.15.148-tegra -
Sensor: RS300, I2C address
0x3c -
Video node:
/dev/video0 -
Current test mode:
640x900,YUYV,30 fps -
CSI route in DT: CSI0 /
serial_a/port-index = <0>/bus-width = <2> -
Physical connection path: Jetson MIPI → MIPI expansion/breakout board → jumper wires → sensor breakout
I confirmed the MIPI clock pair toggles after the stream command is sent.
Media graph:
media-ctl -p | grep -iE 'rs300|nvcsi|vi-output|ENABLED'
Output:
- entity 1: 13e00000.host1x:nvcsi@15a00000- (2 pads, 2 links, 0 routes)
<- "rs300 16-003c":0 [ENABLED]
-> "vi-output, rs300 16-003c":0 [ENABLED]
- entity 4: rs300 16-003c (1 pad, 1 link, 0 routes)
-> "13e00000.host1x:nvcsi@15a00000-":0 [ENABLED]
- entity 6: vi-output, rs300 16-003c (1 pad, 1 link)
<- "13e00000.host1x:nvcsi@15a00000-":1 [ENABLED]
V4L2 state:
v4l2-ctl -d /dev/video0 --all
Relevant output:
Driver name : tegra-video
Card type : vi-output, rs300 16-003c
Video input : 0 (Camera 0: ok)
Format Video Capture:
Width/Height : 640/900
Pixel Format : 'YUYV' (YUYV 4:2:2)
Bytes per Line : 1280
Size Image : 1152000
Streaming Parameters Video Capture:
Frames per second : 30.000 (30/1)
The RS300 driver logs show that the sensor powers on, mode is set, and the stream command succeeds:
rs300 16-003c: rs300_ops: power_on() enter
rs300 16-003c: rs300_ops: power_on() leave ok (state=ON)
rs300 16-003c: rs300_ops: set_mode() enter mode_prop_idx=0
rs300 16-003c: rs300_ops: set_mode() leave ok idx=0
rs300 16-003c: rs300: start_streaming() enter
rs300 16-003c: rs300: vd_stream_start()
rs300 16-003c: rs300: VD start bytes path=0x00 src=0x16 dst=0x03 fps=0x1e 640x900
rs300 16-003c: RS300 Stream Started Successfully
rs300 16-003c: rs300: streaming 640x900 @ 30 fps (VD)
But VI times out:
tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
RTCPU trace shows repeated PHY interrupts:
rtcpu_nvcsi_intr: class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000004
rtcpu_nvcsi_intr: class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000004
Sometimes during shutdown I also see:
rtcpu_nvcsi_intr: class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
rtcpu_nvcsi_intr: class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
I do not see CHANSEL_NOMATCH, SHORT_FRAME, FS, or FE in the trace, only PHY-level interrupts and then VI timeout.
Current relevant DT settings:
mode0 {
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
discontinuous_clk = "no";
cil_settletime = "0";
lane_polarity = "0";
mode_type = "yuv";
pixel_phase = "yuyv";
csi_pixel_bit_depth = "16";
dynamic_pixel_bit_depth = "16";
active_w = "640";
active_h = "900";
line_length = "1280";
pix_clk_hz = "69120000";
embedded_metadata_height = "0";
framerate_factor = "1000000";
min_framerate = "1000000";
max_framerate = "30000000";
default_framerate = "30000000";
ports {
port@0 {
reg = <0>;
rs300_cam0_out: endpoint {
status = "okay";
port-index = <0>;
bus-width = <2>;
data-lanes = <1 2>;
remote-endpoint = <&rs300_nvcsi_in0>;
nvcsi@15a00000 {
channel@0 {
reg = <0>;
status = "okay";
ports {
port@0 {
reg = <0>;
rs300_nvcsi_in0: endpoint@0 {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&rs300_cam0_out>;
port@1 {
reg = <1>;
rs300_nvcsi_out0: endpoint@1 {
remote-endpoint = <&rs300_vi_in0>;
Things I have already tried:
Confirmed media graph links are enabled.
Confirmed
/dev/video0reports640x900 YUYV @ 30 fps. -
Fixed the sensor stream command from 60 fps to 30 fps; driver now sends
fps=0x1e. -
Tried
discontinuous_clk = "yes"and"no"; no fix. -
Tried several
lane_polarityvalues:-
0gives mostlyPHY_INTR status=0x04 -
1gave0x80 -
2and6gave0x44
Tried
data-lanes = <2 1>; no improvement. -
Confirmed MIPI clock toggles after the stream command.
Tried
cil_settletime = "10", but the board became unreachable during boot, so I reverted tocil_settletime = "0".
Questions:
Does
PHY_INTR phy:0 cil:0 status=0x00000004indicate that the Tegra D-PHY is seeing activity but failing to decode valid CSI-2 packets? -
Is the absence of
CHANSEL_NOMATCH,FS,FE, orSHORT_FRAMEa strong sign this is still a physical-layer / lane / signal-integrity issue rather than datatype or frame-size mismatch? -
Are there specific meanings for
PHY_INTR status=0x04,0x44, and0x80on Orin NX? -
Are there additional NVCSI/RTCPU trace events or debugfs nodes I should enable to distinguish between bad signal integrity, wrong lane mapping, P/N polarity issue, and wrong VC/datatype?
Given that the current connection uses a MIPI expansion/breakout board plus jumper wires, is it expected that the receiver might see clock/PHY activity but still fail with
PHY_INTRdue to signal integrity?
Any guidance on how to interpret these PHY interrupt status bits or what to test next would be appreciated.
