[Jetson Orin NX + DeepStream 7.1] Failed in mem copy after running for some time
Hi all,
I’m working on a DeepStream pipeline on a Jetson Orin NX (16GB), but I keep running into an issue where the application fails due to memory copy errors after running for a period of time (sometimes after 1 minute, sometimes after 10). I’m hoping someone can help me identify what might be going wrong.
Environment
• Hardware Platform (Jetson / GPU) Jetson Orin NX (16GB)
• DeepStream Version 7.1
• JetPack Version (valid for Jetson only) 6.2
• TensorRT Version 10.3.0.30
• Issue Type( questions, new requirements, bugs) bugs
Pipeline:
v4l2src → capsfilter → nvv4l2decoder → nvvideoconvert → capsfilter → nvstreammux → nvinfer → nvtracker → appsink
Model:
Self-trained YOLOv7 model
Issue
After running my DeepStream app for a while, it crashes with the following errors:
cudaMemcpy2DAsync failed with error cudaErrorIllegalAddress
nvbufsurftransform_copy.cpp:438 => Failed in mem copy
get_converted_buffer failed
gst_nvinfer_process_full_frame: error: Buffer conversion failed
Sometimes, I also see:
PyCUDA ERROR: The context stack was not empty upon module cleanup.
What I’ve Tried:
I’ve followed suggestions from other threads and tried adjusting nvbuf-memory-type and compute-hw in the pipeline:
  • compute-hw=1 (result: buffer transform failed after a short run)
  • nvbuf-memory-type=3 (error: NVBUF_MEM_CUDA_UNIFIED not supported)
  • nvbuf-memory-type=4 (stream works briefly then same mem copy error)
Please let me know if additional logs or config files would be helpful. Thanks in advance!
My guess is that the buffer’s memory is being accessed after it has been released by GStreamer. I’m not sure how you’re obtaining the buffer, but you might try using gst_buffer_ref to increase the buffer’s reference count. This ensures the buffer isn’t prematurely freed. Just make sure to call gst_buffer_unref once you’re done with it to avoid memory leaks.
Some other things you can try:
  • Replace appsink with fakesink to verify that the illegal access is located in your appsink.
  • Set nvbuf-memory-type=0, you should use this unless there is a memory issue.
  • Try using cuda-memcheck ./your_app.
  • Enable GStreamer debug to get more information export GST_DEBUG=3.
Could you try to just set the copy-hw=2 for the nvvideoconvert plugin?
@miguel.taylor
Hi, thanks for the detailed suggestions!
I’ll definitely try replacing appsink with fakesink to check whether the illegal access is happening downstream. Also planning to run cuda-memcheck ./app and will report back with any specific findings.
As for gst_buffer_ref(), I’m not manually accessing buffers in the pipeline — it’s all handled through GStreamer elements — but I’ll inspect any interaction around appsink just in case.
For nvbuf-memory-type=0, I did test it and enabled GST_DEBUG=3. Unfortunately, I still got the following errors:
/dvs/git/dirty/git-master_linux/nvutils/nvbufsurftransform/nvbufsurftransform_copy.cpp:438 => Failed in mem copy
cuDCFFrameTransformTexture.cu 693
gstnvtracker: Low-level tracker lib returned error 1
gst_nvinfer_process_full_frame: Buffer conversion failed
I have attached a more detailed log for your convenience.
nvbuf-memory-type = 0.txt (1.5 KB)
Appreciate the help — will update again after running the fakesink and cuda-memcheck tests.
@yuweiw
Hi yuweiw, thanks for the tip!
I tested with copy-hw=2 on the nvvideoconvert plugin and enabled GST_DEBUG=3.
Unfortunately, I still encountered the same memory copy failures and illegal access errors.
I’ve attached the full log file in case there’s anything you spot.
copy-hw = 2.txt (2.6 KB)
Let me know if you think I should adjust other parameters.
Thanks again!
    1. Have you only set this one memory-related parameter for the nvvideoconvert in the pipeline? You don’t need to set any other memory-related parameters for other plugins in the pipeline.
  • 2.Could you narrow down the scope by reducing the number of plugins? Like replacing the v4l2src to the filesrc, delete the nvinfer and nvtracker plugins, etc…
Hi yuweiw,
  1. Yes, I’ve only set the copy-hw=2 parameter on the nvvideoconvert element before nvinfer. There are no other memory-related parameters set for any other plugins in the pipeline.
  2. I’ve tried narrowing down the pipeline by removing plugins. Through this process, it seems the issue might be related to the appsink. Interestingly, even when I replace appsink with autovideosink, the problem still persists.
How did you confirm that? What if you use the nv3dsink?
