Hi there,
Actually I installed microk8s kubernetes single node cluster in Nvidia jetson orin.
After the installation I receice the warning like, WARNING: cannot create user data directory: failed to verify SELinux context of /home/nvidia/snap: exec: “matchpathcon”: executable file not found in $PATH
Then I installed sudo apt-get install policycoreutils. and sudo init 6
After that HDMI connection lost. Even I changed my HDMI cable and monitor.But the issue persists.
Unable to SSH into the device or even ping it, I think that the system might not be booting correctly or is not properly connected to the network.
Could u people please help me to sort this out or is that any option to recover?
There is no board called “Orin NX developer kit recomputer J4012”.
Orin NX developer kit is a official carrier board from NVIDIA and recomputer J4012 is a custom board from vendor.
This is just a custom carrier board.
Please try to dump the log in above stage and see what status it is.
As your board is different from NV devkit, I don’t guarantee above method to dump log would work on your side. If it does not have such pin, please contact board vendor for help.
