Jetson Orin Nx device has a missing boot kernel and prompts partition size related errors during flashing
The Jetson Orin Nx device cannot enter the system upon startup, and the startup interface reports an error indicating that the image cannot be loaded and the kernel is missing. Multiple attempts to flash the device were unsuccessful. When reinstalling Jetpack 5.1.1, the partition size related error message is as follows:
Verified that the SSD installed in the Orin Nx flash drive reads normally.
Get size of partition through connection.
l4t_flash_from_kernel: The device size indicated in the partition layout xml is smaller than the actual size. This utility will try to fix the GPT.
l4t_flash_from_kernel: Error flashing external device
Flash failure
Cleaning up…
Is this a NV devkit or custom board? The error is that nvme input/output error.
It is an NV devkit. Okay, thank you for your answer. I’ll try replacing the hard drive.
