Jetson Orin NX (JetPack 6.2 / L4T R36.4.3) – source_sync.sh fails with nv-tegra connection error
I’m working with the Jetson Orin NX and JetPack 6.2 (L4T R36.4.3), and I’m trying to download kernel and device tree sources using the provided source_sync.sh script.
Here’s the command I ran:
./source_sync.sh -k tegra-l4t-r36.4.3
But it fails for all repositories with the following error:
fatal: unable to connect to nv-tegra.nvidia.com: Connection refused
  1. Is there an alternate way to fetch the kernel and device tree sources for R36.4.3?
  2. Is nv-tegra.nvidia.com deprecated or region-restricted?
Thanks in advance!
When reference is changed from git:// to http:// in source_sync.sh:
fatal: unable to access ‘http://nv-tegra.nvidia.com/3rdparty/canonical/linux-jammy.git/’: Failed to connect to nv-tegra.nvidia.com port 80 after 216456 ms: Connection timed out
Here release tag is wrong. Refer release notes pdf for correct release tag.
The server connection issue should be fixed, please help to get it a try.
