Jetson ORIN NX low temperature limit
I have found during testing the ORIN NX that the minimum start-up temperature of -25’C is actually pretty accurate. At temperatures below -25’C the behaviour is consistent, an initial current draw then dropping back to a low value. No activity after this, i.e. not starting.
I would like to be able to start the ORIN NX at -32’C and -40’C to meet our customer requirements and qualify reliable operation, including operating at these temperatures continuously.
BTW. The Xavier NX is generally capable of starting at -32’C in practice which I discovered (and also speced to -25’C)
I am designing a pre-heating solution for the ORIN NX. It will be fairly localised under our heat-spreader (two 3D printer cylindrical elements to start with and a controller board).
My questions is: what is the ‘component or components’ on the ORIN NX that would be limiting cold start? It could perhaps be: SoC, DRAM; clock osc.; vregulators; etc. etc.
If I know the area to concentrate the warm-up I can perhaps use less power, better targeted.
The follow on question from this would be:
Once the ORIN NX has been started, and it will be happily generating self-heating. Would it be practical to then reduce the external ambient below the -25’C limit without issue. It is likely to be in a fairly static benign space, i.e. no fans directing airflow towards the module.
We can do further testing on this aspect once the initial start-up problem is worked out.
Just to confirm all the components which we have used in our design are rated to -40’C to +85’C or more including the SSD (Renice).
We don’t suggest to do that.
Also, there are multiple sensors around the module and bootloader will check the temperature of all sensors limit during boot.
