Thank you for reaching out to the community for insight into the thermal stress testing issue you’re experiencing with the Jetson Orin NX.
Expected Behavior when LPDDR5 Temperature Crosses its Thermal Limit
According to the Thermal Specifications document, when the internal temperature of the Jetson Orin NX module reaches an unsafe temperature, the hardware is designed to initiate a shutdown. This is a protective measure to prevent damage to the module. The expected behavior in this scenario is a thermal shutdown, which is a hardware shutdown triggered by on-chip and on-board sensors when all other cooling strategies have failed and software shutdown has failed to occur.
Monitoring LPDDR5 Temperatures
The Jetson Orin NX module has built-in temperature monitoring capabilities. The module can report and take action when internal temperature exceeds limits. However, it’s not clear if the LPDDR5 temperature is specifically monitored or if the shutdown happens at the SoM (System-on-Module) level. It’s possible that the LPDDR5 temperature is not directly monitored, but rather the overall module temperature is monitored, which includes the LPDDR5 component.
Community Experiences with LPDDR5 Overheating
There are a few threads in the community forum that mention thermal-related issues with the Jetson Orin NX, but none specifically mention LPDDR5 overheating. However, one thread mentions a shutdown issue with the Jetson Orin NX 16G module, which could be related to thermal stress.
Determining if the Shutdown is an Expected Protective Shutdown or a Design/Thermal Margin Issue
To determine if the shutdown is an expected protective shutdown or a design/thermal margin issue, you may want to investigate the following:
- Check the thermal design of your carrier or enclosure to ensure it meets the thermal specifications of the Jetson Orin NX module.
- Verify that the module is properly cooled and that the cooling system is functioning correctly.
- Review the power and thermal management settings on your system to ensure they are configured correctly.
- Check the system logs to see if there are any error messages or warnings related to thermal stress or shutdown.
If you’ve checked all of these and the issue persists, it’s possible that there’s a design or thermal margin issue with your carrier or enclosure.
Comparison with Other Jetson Modules
The Jetson Orin NX module has a similar thermal shutdown mechanism to other Jetson modules, such as the Jetson AGX Xavier. However, the specific thermal specifications and monitoring capabilities may differ between modules.
In summary, the expected behavior when LPDDR5 temperature crosses its thermal limit is a thermal shutdown, which is a protective measure to prevent damage to the module. While there are some community threads that mention thermal-related issues with the Jetson Orin NX, none specifically mention LPDDR5 overheating. To determine if the shutdown is an expected protective shutdown or a design/thermal margin issue, you should investigate the thermal design of your carrier or enclosure, verify proper cooling, review power and thermal management settings, and check system logs.
