Hi team,
I use both Jetson Orin NX Module 8GB and Jetson Orin NX Module 16GB with Waveshare base board (Jetson Orin Nano/NX AI Development Board, Waveshare Orin Nano/NX Development Board Based on Jetson Orin Nano and Jetson Orin NX module | JETSON-ORIN-IO-BASE).
=> Using Jetson Orin NX Module 8GB: when pressing Shutdown, the module turns off normally, and the power light on the base circuit turns off after pressing Shutdown.
=> Using Jetson Orin NX Module 16GB: when pressing Shutdown, the module cannot shut down, The power light on the base board stays ON after pressing Shutdown, and after a while (about 2~3 minutes) the module automatically restarts.
I also used: Jetpack 5.1.2, Jetpack 5.1.4, and Jetpack 6.0 to test and all had this problem with Jetson Orin NX Module 16GB: The power light on the base board stays ON after pressing Shutdown, and after a while (about 2~3 minutes) the module restarts itself.
Please check and support me. Thanks!
