As described in the design guide, Orin NX only supports 1 display out (DP/eDP or HDMI). If I want to output two HDMI channels, can I use other interfaces and protocol conversion chips to output?
Does Orin NX have a recommended design for two or multiple display outputs?
Thank you for your reminder. Do Orin NX have a recommended DP MST HUB reference design? (The chipset one DP in, two HDMI out) we want to make two channels of HDMI out.
Looking forward to your reply, thank you!
