Here you go:
Jetson System firmware version 36.4.3-gcid-38968081 date 2025-01-08T01:18:20+00:
00
ESC to enter Setup.
F11 to enter Boot Manager Menu.
Enter to continue boot.
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel…
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services…
��debugfs initialized
��I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
��[ 0.000000] Booting Linux on physical CPU 0x0000010000 [0x410fd421]
[ 0.000000] Linux version 5.15.148-tegra (buildbrain@mobile-u64-6336-d8000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2022.08) 11.3.0, GNU ld (GNU)
[ 0.000000] Machine model: NVIDIA Jetson Orin NX Engineering Reference Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x46d82f198 TPMFinalLog=0x45e3f0000 SMBIOS=0xffff0000 SMBIOS 3.0=0x46d220000 MEMATTR=0x467130018 ESRT=0x467186698 TPMEventLog=0x45e4
[ 0.000000] random: crng init done
[ 0.000000] secureboot: Secure boot disabled
[ 0.000000] esrt: Reserving ESRT space from 0x0000000467186698 to 0x00000004671866d0.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000044a000000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000000477ffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x4702fc800-0x4702fefff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000000477ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000bdffffff]
[ 0.000000] node 0: [mem 0x00000000c2000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000045e21dfff]
[ 0.000000] node 0: [mem 0x000000045e21e000-0x000000045e3fffff]
[ 0.000000] node 0: [mem 0x000000045e400000-0x000000045e40afff]
[ 0.000000] node 0: [mem 0x000000045e40b000-0x000000045e40bfff]
[ 0.000000] node 0: [mem 0x000000045e40c000-0x000000046b8effff]
[ 0.000000] node 0: [mem 0x000000046b8f0000-0x000000046d82ffff]
[ 0.000000] node 0: [mem 0x000000046d830000-0x0000000471dfffff]
[ 0.000000] node 0: [mem 0x0000000471e00000-0x0000000471ffffff]
[ 0.000000] node 0: [mem 0x0000000472000000-0x000000047259ffff]
[ 0.000000] node 0: [mem 0x0000000472f00000-0x0000000472ffffff]
[ 0.000000] node 0: [mem 0x0000000476000000-0x0000000477ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000477ffffff]
[ 0.000000] On node 0, zone DMA: 16384 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 2400 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 12288 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 29 pages/cpu s80408 r8192 d30184 u118784
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Address authentication (architected algorithm)
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: detected: Hardware dirty bit management
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 4065440
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: root=PARTUUID=4c167da0-686b-4388-84a4-294a13491f8a rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 fir
[ 0.000000] Unknown kernel command line parameters “bl_prof_dataptr=2031616@0x471E10000 bl_prof_ro_ptr=65536@0x471E00000”, will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000fbfe0000-0x00000000fffe0000] (64MB)
[ 0.000000] Memory: 15746896K/16521856K available (20160K kernel code, 4064K rwdata, 10060K rodata, 7680K init, 529K bss, 512816K reserved, 262144K cma-rese)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000000] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000331] Console: colour dummy device 80x25
[ 0.000337] printk: console [tty0] enabled
[ 0.000378] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000383] pid_max: default: 32768 minimum: 301
[ 0.000409] LSM: Security Framework initializing
[ 0.000424] Yama: becoming mindful.
[ 0.000434] SELinux: Initializing.
[ 0.000496] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.000516] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.001352] rcu: Hierarchical SRCU implementation.
[ 0.003387] Tegra Revision: A01 SKU: 211 CPU Process: 0 SoC Process: 0
[ 0.003632] Remapping and enabling EFI services.
[ 0.004397] smp: Bringing up secondary CPUs …
[ 0.004759] Detected PIPT I-cache on CPU1
[ 0.004785] GICv3: CPU1: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.004810] CPU1: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.005151] Detected PIPT I-cache on CPU2
[ 0.005162] GICv3: CPU2: found redistributor 10200 region 0:0x000000000f500000
[ 0.005175] CPU2: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.005483] Detected PIPT I-cache on CPU3
[ 0.005492] GICv3: CPU3: found redistributor 10300 region 0:0x000000000f520000
[ 0.005503] CPU3: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.007899] Detected PIPT I-cache on CPU4
[ 0.007925] GICv3: CPU4: found redistributor 20000 region 0:0x000000000f540000
[ 0.007950] CPU4: Booted secondary processor 0x0000020000 [0x410fd421]
[ 0.008415] Detected PIPT I-cache on CPU5
[ 0.008427] GICv3: CPU5: found redistributor 20100 region 0:0x000000000f560000
[ 0.008441] CPU5: Booted secondary processor 0x0000020100 [0x410fd421]
[ 0.008860] Detected PIPT I-cache on CPU6
[ 0.008872] GICv3: CPU6: found redistributor 20200 region 0:0x000000000f580000
[ 0.008885] CPU6: Booted secondary processor 0x0000020200 [0x410fd421]
[ 0.009324] Detected PIPT I-cache on CPU7
[ 0.009336] GICv3: CPU7: found redistributor 20300 region 0:0x000000000f5a0000
[ 0.009349] CPU7: Booted secondary processor 0x0000020300 [0x410fd421]
[ 0.009403] smp: Brought up 1 node, 8 CPUs
[ 0.009407] SMP: Total of 8 processors activated.
[ 0.009410] CPU features: detected: 32-bit EL0 Support
[ 0.009411] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.009414] CPU features: detected: Common not Private translations
[ 0.009415] CPU features: detected: CRC32 instructions
[ 0.009415] CPU features: detected: Data cache clean to Point of Persistence
[ 0.009417] CPU features: detected: Generic authentication (architected algorithm)
[ 0.009418] CPU features: detected: RCpc load-acquire (LDAPR)
[ 0.009419] CPU features: detected: LSE atomic instructions
[ 0.009420] CPU features: detected: Privileged Access Never
[ 0.009421] CPU features: detected: RAS Extension Support
[ 0.009423] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.023842] spectre-bhb mitigation disabled by command line option
[ 0.037152] CPU: All CPU(s) started at EL2
[ 0.038918] devtmpfs: initialized
[ 0.049358] KASLR enabled
[ 0.049460] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.049473] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.051568] pinctrl core: initialized pinctrl subsystem
[ 0.052083] SMBIOS 3.6.0 present.
[ 0.052091] DMI: NVIDIA NVIDIA Jetson Orin NX Engineering Reference Developer Kit/Jetson, BIOS 36.4.3-gcid-38968081 01/08/2025
[ 0.052374] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.053530] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[ 0.053635] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.053726] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.053760] audit: initializing netlink subsys (disabled)
[ 0.053849] audit: type=2000 audit(0.052:1): state=initialized audit_enabled=0 res=1
[ 0.054737] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.054741] thermal_sys: Registered thermal governor ‘user_space’
[ 0.054743] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.056759] cpuidle: using governor menu
[ 0.056884] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.056965] ASID allocator initialised with 32768 entries
[ 0.058081] Serial: AMBA PL011 UART driver
[ 0.066331] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 117, base_baud = 0) is a SBSA
[ 0.074018] platform bpmp: Fixing up cyclic dependency with 2c60000.external-memory-controller
[ 0.080499] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.080504] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.080505] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.080506] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.081139] cryptd: max_cpu_qlen set to 1000
[ 0.082471] ACPI: Interpreter disabled.
[ 0.083339] VDD_1V8_AO: supplied by VDD_5V0_SYS
[ 0.083428] VDD_3V3_AO: supplied by VDD_5V0_SYS
[ 0.083570] VDD_AV10_HUB: supplied by VDD_5V0_SYS
[ 0.083881] iommu: Default domain type: Translated
[ 0.083885] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.084066] SCSI subsystem initialized
[ 0.084169] vgaarb: loaded
[ 0.084268] usbcore: registered new interface driver usbfs
[ 0.084280] usbcore: registered new interface driver hub
[ 0.084289] usbcore: registered new device driver usb
[ 0.084603] pps_core: LinuxPPS API ver. 1 registered
[ 0.084605] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.084612] PTP clock support registered
[ 0.084660] EDAC MC: Ver: 3.0.0
[ 0.085301] Registered efivars operations
[ 0.085720] FPGA manager framework
[ 0.085779] Advanced Linux Sound Architecture Driver Initialized.
[ 0.086048] Bluetooth: Core ver 2.22
[ 0.086063] NET: Registered PF_BLUETOOTH protocol family
[ 0.086065] Bluetooth: HCI device and connection manager initialized
[ 0.086070] Bluetooth: HCI socket layer initialized
[ 0.086073] Bluetooth: L2CAP socket layer initialized
[ 0.086079] Bluetooth: SCO socket layer initialized
[ 0.086346] clocksource: Switched to clocksource arch_sys_counter
[ 0.104277] VFS: Disk quotas dquot_6.6.0
[ 0.104314] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.104426] pnp: PnP ACPI: disabled
[ 0.106675] NET: Registered PF_INET protocol family
[ 0.106889] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.109026] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.109097] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.109108] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.109217] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.109771] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.109862] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.109895] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.110014] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.110240] RPC: Registered named UNIX socket transport module.
[ 0.110243] RPC: Registered udp transport module.
[ 0.110243] RPC: Registered tcp transport module.
[ 0.110244] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.110252] PCI: CLS 0 bytes, default 64
[ 0.110390] Unpacking initramfs…
[ 0.118885] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counters available
[ 0.119031] kvm [1]: IPA Size Limit: 48 bits
[ 0.119048] kvm [1]: GICv3: no GICV resource entry
[ 0.119051] kvm [1]: disabling GICv2 emulation
[ 0.119062] kvm [1]: GIC system register CPU interface enabled
[ 0.119137] kvm [1]: vgic interrupt IRQ9
[ 0.119247] kvm [1]: VHE mode initialized successfully
[ 0.121193] Initialise system trusted keyrings
[ 0.121213] Key type blacklist registered
[ 0.121279] workingset: timestamp_bits=42 max_order=22 bucket_order=0
[ 0.123347] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.123598] NFS: Registering the id_resolver key type
[ 0.123618] Key type id_resolver registered
[ 0.123620] Key type id_legacy registered
[ 0.123650] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.123659] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 0.123671] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.123811] 9p: Installing v9fs 9p2000 file system support
[ 0.124145] integrity: Platform Keyring initialized
[ 0.135692] Key type asymmetric registered
[ 0.135694] Asymmetric key parser ‘x509’ registered
[ 0.135738] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.135742] io scheduler mq-deadline registered
[ 0.135745] io scheduler kyber registered
[ 0.142418] EINJ: ACPI disabled.
[ 0.150365] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.151446] SuperH (H)SCI(F) driver initialized
[ 0.151687] msm_serial: driver initialized
[ 0.152099] printk: console [ttyTCU0] enabled
[ 0.152726] arm-smmu 8000000.iommu: probing hardware configuration…
[ 0.152729] arm-smmu 8000000.iommu: SMMUv2 with:
[ 0.152733] arm-smmu 8000000.iommu: stage 1 translation
[ 0.152735] arm-smmu 8000000.iommu: stage 2 translation
[ 0.152735] arm-smmu 8000000.iommu: nested translation
[ 0.152737] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 0.152740] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 0.152750] arm-smmu 8000000.iommu: Supported page sizes: 0x61311000
[ 0.152752] arm-smmu 8000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.152753] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.153506] arm-smmu 10000000.iommu: probing hardware configuration…
[ 0.153508] arm-smmu 10000000.iommu: SMMUv2 with:
[ 0.153509] arm-smmu 10000000.iommu: stage 1 translation
[ 0.153510] arm-smmu 10000000.iommu: stage 2 translation
[ 0.153511] arm-smmu 10000000.iommu: nested translation
[ 0.153512] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 0.153514] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 0.153517] arm-smmu 10000000.iommu: Supported page sizes: 0x61311000
[ 0.153518] arm-smmu 10000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.153519] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.153809] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.153811] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.153812] arm-smmu 12000000.iommu: stage 1 translation
[ 0.153813] arm-smmu 12000000.iommu: stage 2 translation
[ 0.153814] arm-smmu 12000000.iommu: nested translation
[ 0.153815] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 0.153817] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 0.153819] arm-smmu 12000000.iommu: Supported page sizes: 0x61311000
[ 0.153820] arm-smmu 12000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 0.153821] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 0.158529] loop: module loaded
[ 0.159064] megasas: 07.717.02.00-rc1
[ 0.161621] tun: Universal TUN/TAP device driver, 1.6
[ 0.161991] thunder_xcv, ver 1.0
[ 0.162007] thunder_bgx, ver 1.0
[ 0.162020] nicpf, ver 1.0
[ 0.162574] hclge is initializing
[ 0.162591] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 0.162594] hns3: Copyright (c) 2017 Huawei Corporation.
[ 0.162616] e1000: Intel(R) PRO/1000 Network Driver
[ 0.162618] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 0.162631] e1000e: Intel(R) PRO/1000 Network Driver
[ 0.162632] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 0.162645] igb: Intel(R) Gigabit Ethernet Network Driver
[ 0.162647] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 0.162655] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.162656] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.162790] sky2: driver version 1.30
[ 0.163247] VFIO - User Level meta-driver version: 0.3
[ 0.164186] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.164189] ehci-pci: EHCI PCI platform driver
[ 0.164201] ehci-platform: EHCI generic platform driver
[ 0.164254] ehci-orion: EHCI orion driver
[ 0.164300] ehci-exynos: EHCI Exynos driver
[ 0.164338] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.164349] ohci-pci: OHCI PCI platform driver
[ 0.164361] ohci-platform: OHCI generic platform driver
[ 0.164407] ohci-exynos: OHCI Exynos driver
[ 0.164689] usbcore: registered new interface driver usb-storage
[ 0.165843] i2c_dev: i2c /dev entries driver
[ 0.166779] pps pps0: new PPS source ktimer
[ 0.166788] pps pps0: ktimer PPS source registered
[ 0.166795] pps_ldisc: PPS line discipline registered
[ 0.168762] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[ 0.170936] sdhci: Secure Digital Host Controller Interface driver
[ 0.170941] sdhci: Copyright(c) Pierre Ossman
[ 0.171395] Synopsys Designware Multimedia Card Interface Driver
[ 0.171966] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.173008] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.174085] SMCCC: SOC_ID: ID = jep106:036b:0234 Revision = 0x00000401
[ 0.174533] tegra-bpmp bpmp: Adding to iommu group 0
[ 0.175906] tegra-bpmp bpmp: firmware: dc3fd3cac60f9b918e11-da583751bbf
[ 0.336483] Freeing initrd memory: 14560K
[ 4.272258] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 4.272280] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 49772407460 ns
[ 4.272282] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 4.272414] hid: raw HID events driver (C) Jiri Kosina
[ 4.272699] usbcore: registered new interface driver usbhid
[ 4.272704] usbhid: USB HID core driver
[ 4.277019] optee: probing for conduit method.
[ 4.277070] optee: revision 4.2 (d78bc5fa)
[ 4.336386] optee: dynamic shared memory is enabled
[ 4.336655] optee: initialized driver
[ 4.339110] usbcore: registered new interface driver snd-usb-audio
[ 4.340563] NET: Registered PF_PACKET protocol family
[ 4.341611] Bluetooth: RFCOMM TTY layer initialized
[ 4.341639] Bluetooth: RFCOMM socket layer initialized
[ 4.341668] Bluetooth: RFCOMM ver 1.11
[ 4.341949] 9pnet: Installing 9P2000 support
[ 4.342079] Key type dns_resolver registered
[ 4.343603] printk: console [tty0]: printing thread started
[ 4.344162] printk: console [ttyTCU0]: printing thread started
[ 4.344304] Loading compiled-in X.509 certificates
[ 4.347244] Loaded X.509 cert ‘Build time autogenerated kernel key: 6ad7eb1abc7541e974a48fc505964410c4019a6e’
[ 4.436665] simple-framebuffer chosen:framebuffer: framebuffer at 0x47de00000, 0x1680000 bytes
[ 4.436678] simple-framebuffer chosen:framebuffer: format=x8r8g8b8, mode=2560x1440x32, linelength=16384
[ 4.444662] Console: switching to colour frame buffer device 320x90
[ 4.449595] simple-framebuffer chosen:framebuffer: fb0: simplefb registered!
[ 4.450450] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[ 4.451980] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 channels
[ 4.453303] serial-tegra 3100000.serial: RX in PIO mode
[ 4.453308] serial-tegra 3100000.serial: TX in PIO mode
[ 4.453382] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[ 4.453930] 3140000.serial: ttyTHS2 at MMIO 0x3140000 (irq = 113, base_baud = 0) is a TEGRA_UART
[ 4.456143] tegra_rtc c2a0000.rtc: registered as rtc1
[ 4.456152] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.456664] tegra-i2c 3160000.i2c: Adding to iommu group 1
[ 4.460602] tegra-i2c 3180000.i2c: Adding to iommu group 1
[ 4.464096] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[ 4.467231] tegra-i2c c240000.i2c: Adding to iommu group 1
[ 4.470143] i2c 1-0025: Fixing up cyclic dependency with 3520000.padctl
[ 4.470684] tegra-i2c c250000.i2c: Adding to iommu group 1
[ 4.494991] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1998000 KHz, changing to: 1984000 KHz
[ 4.497006] tegra-xusb 3610000.usb: Adding to iommu group 2
[ 4.513664] tegra-xusb 3610000.usb: Firmware timestamp: 2023-02-10 03:48:10 UTC
[ 4.513671] tegra-xusb 3610000.usb: xHCI Host Controller
[ 4.513681] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 1
[ 4.514433] tegra-xusb 3610000.usb: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000010810
[ 4.514450] tegra-xusb 3610000.usb: irq 123, io mem 0x03610000
[ 4.514555] tegra-xusb 3610000.usb: xHCI Host Controller
[ 4.514559] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 2
[ 4.514562] tegra-xusb 3610000.usb: Host supports USB 3.1 Enhanced SuperSpeed
[ 4.514764] hub 1-0:1.0: USB hub found
[ 4.514777] hub 1-0:1.0: 4 ports detected
[ 4.515035] hub 2-0:1.0: USB hub found
[ 4.515046] hub 2-0:1.0: 4 ports detected
[ 4.517170] irq: IRQ227: trimming hierarchy from :bus@0:pmc@c360000
[ 4.517226] irq: IRQ228: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[ 4.517308] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 4.610673] ALSA device list:
[ 4.610678] No soundcards found.
[ 4.637333] Freeing unused kernel memory: 7680K
[ 4.637410] Run /init as init process
[ 4.653001] Checking overlayfs setting…
[ 4.661878] Overlayfs is disabled…
[ 4.667367] Root device found: PARTUUID=4c167da0-686b-4388-84a4-294a13491f8a
[ 4.854347] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 5.007860] hub 1-2:1.0: USB hub found
[ 5.008333] hub 1-2:1.0: 6 ports detected
[ 5.130896] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 5.160581] hub 2-1:1.0: USB hub found
[ 5.161378] hub 2-1:1.0: 4 ports detected
[ 5.302355] usb 1-2.1: new full-speed USB device number 3 using tegra-xusb
[ 5.418917] input: Logitech USB Receiver as /devices/platform/bus@0/3610000.usb/usb1/1-2/1-2.1/1-2.1:1.0/0003:046D:C534.0001/input/input1
[ 5.478706] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-3610000.usb-2.1/input0
[ 5.482778] input: Logitech USB Receiver Mouse as /devices/platform/bus@0/3610000.usb/usb1/1-2/1-2.1/1-2.1:1.1/0003:046D:C534.0002/input/input2
[ 5.482837] input: Logitech USB Receiver Consumer Control as /devices/platform/bus@0/3610000.usb/usb1/1-2/1-2.1/1-2.1:1.1/0003:046D:C534.0002/input/input3
[ 5.483633] usb 2-1.2: new SuperSpeed USB device number 3 using tegra-xusb
[ 5.514262] usb 2-1.2: LPM exit latency is zeroed, disabling LPM.
[ 5.542418] input: Logitech USB Receiver System Control as /devices/platform/bus@0/3610000.usb/usb1/1-2/1-2.1/1-2.1:1.1/0003:046D:C534.0002/input/input4
[ 5.542474] hid-generic 0003:046D:C534.0002: input,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-3610000.usb-2.1/input1
[ 5.622348] usb 1-2.3: new full-speed USB device number 4 using tegra-xusb
[ 5.810526] usb 1-2.4: new full-speed USB device number 5 using tegra-xusb
[ 6.006520] usb 1-2.5: new high-speed USB device number 6 using tegra-xusb
[ 6.112224] hid-generic 0003:0451:82FF.0003: hidraw2: USB HID v1.11 Device [HID 0451:82ff] on usb-3610000.usb-2.5/input0
[ 15.625499] ERROR: mounting PARTUUID=4c167da0-686b-4388-84a4-294a13491f8a as /mnt fail…
[ 15.628552] ERROR: PARTUUID=4c167da0-686b-4388-84a4-294a13491f8a mount fail…
[ 15.630152] ttyTCU0: Press [ENTER] to start bash in 30 seconds…
[ 18.630597] ttyTCU0: Press [ENTER] to start bash in 27 seconds…
[ 21.630761] ttyTCU0: Press [ENTER] to start bash in 24 seconds…
[ 22.581846] Starting bash…
