Jetson Orin NX PCIE C9 Jetpack5.1.4 无法打开使用
嗨,我使用了Jetpack5.1.4的版本,参照着上次Jetson 5.1.1的更改方法更改了设备树,然后将生成的dtb文件替换到源码里,同时使用表格内的文件生成了pinmux.dtsi等3个文件,更改了配置文件,我发现配置文件中相比于5.1.1多了一行
“OVERLAY_DTB_FILE="${OVERLAY_DTB_FILE},tegra234-p3768-overlay.dtbo”我不知道这一行是否会对结果有帮助?
DEFAULT_EMC_FUSE="0";
PINMUX_CONFIG="pinmux.dtsi";
PMC_CONFIG="padvoltage.dtsi";
BPFDTB_FILE="tegra234-bpmp-3767-0000-a02-3509-a02.dtb";
DTB_FILE="tegra234-p3767-0000-p3768-0000-a0-modify.dtb";
TBCDTB_FILE="${DTB_FILE}";
EMMC_CFG="flash_t234_qspi_sd.xml";
OVERLAY_DTB_FILE="${OVERLAY_DTB_FILE},tegra234-p3768-overlay.dtbo";
ODMDATA="gbe-uphy-config-9,hsstp-lane-map-3,hsio-uphy-config-0";
然而开机后PCIE C9 1-Line无法使用,以下是我的开机日志和反编译生成的文件,我注意到一个错误:Failed to get slot regulators: -517
能帮我看看是什么原因吗?
kuper@kuper:~$ sudo dmesg | grep pcie
[    6.398769] tegra194-pcie 14100000.pcie: Adding to iommu group 7
[    6.411492] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[    6.418893] tegra194-pcie 14160000.pcie: Adding to iommu group 8
[    6.431048] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[    6.437918] tegra194-pcie 141e0000.pcie: Adding to iommu group 9
[    6.449819] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[    6.456617] tegra194-pcie 140a0000.pcie: Adding to iommu group 10
[    6.468611] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[    6.476033] tegra194-pcie 140a0000.pcie: Failed to get slot regulators: -517
[    6.476181] tegra194-pcie 140c0000.pcie: Adding to iommu group 11
[    6.488446] tegra194-pcie 140c0000.pcie: Using GICv2m MSI allocator
[    7.793483] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[    7.800940] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[    7.808111] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff -> 0x0030100000
[    7.816802] tegra194-pcie 14100000.pcie:      MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[    7.825488] tegra194-pcie 14100000.pcie:      MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[    8.932939] tegra194-pcie 14100000.pcie: Phy link never came up
[    8.939108] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[    9.013962] pcieport 0001:00:00.0: Adding to iommu group 7
[    9.019837] pcieport 0001:00:00.0: PME: Signaling with IRQ 55
[    9.026039] pcieport 0001:00:00.0: AER: enabled with IRQ 55
[    9.051629] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[    9.079224] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[    9.093918] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[    9.102617] tegra194-pcie 14160000.pcie:      MEM 0x2428000000..0x242fffffff -> 0x0040000000
[    9.111316] tegra194-pcie 14160000.pcie:      MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[    9.224926] tegra194-pcie 14160000.pcie: Link up
[    9.230755] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[    9.366979] pcieport 0004:00:00.0: Adding to iommu group 8
[    9.372857] pcieport 0004:00:00.0: PME: Signaling with IRQ 57
[    9.379089] pcieport 0004:00:00.0: AER: enabled with IRQ 57
[    9.421285] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[    9.422410] tegra194-pcie 141e0000.pcie: host bridge /pcie@141e0000 ranges:
[    9.422417] tegra194-pcie 141e0000.pcie:       IO 0x003e100000..0x003e1fffff -> 0x003e100000
[    9.422421] tegra194-pcie 141e0000.pcie:      MEM 0x3228000000..0x322fffffff -> 0x0040000000
[    9.422423] tegra194-pcie 141e0000.pcie:      MEM 0x2e40000000..0x3227ffffff -> 0x2e40000000
[    9.528931] tegra194-pcie 141e0000.pcie: Link up
[    9.534777] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[    9.739307] pcieport 0007:00:00.0: Adding to iommu group 9
[    9.745216] pcieport 0007:00:00.0: PME: Signaling with IRQ 59
[    9.751397] pcieport 0007:00:00.0: AER: enabled with IRQ 59
[    9.758061] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[    9.764623] tegra194-pcie 140a0000.pcie: Failed to get slot regulators: -517
[    9.765094] tegra194-pcie 140c0000.pcie: Using GICv2m MSI allocator
[    9.772575] tegra194-pcie 140c0000.pcie: host bridge /pcie@140c0000 ranges:
[    9.779760] tegra194-pcie 140c0000.pcie:       IO 0x002c100000..0x002c1fffff -> 0x002c100000
[    9.788460] tegra194-pcie 140c0000.pcie:      MEM 0x3828000000..0x382fffffff -> 0x0040000000
[    9.797148] tegra194-pcie 140c0000.pcie:      MEM 0x3540000000..0x3827ffffff -> 0x3540000000
[   10.913760] tegra194-pcie 140c0000.pcie: Phy link never came up
[   10.919937] tegra194-pcie 140c0000.pcie: PCI host bridge to bus 0009:00
[   10.994920] pcieport 0009:00:00.0: Adding to iommu group 11
[   11.000863] pcieport 0009:00:00.0: PME: Signaling with IRQ 63
[   11.007031] pcieport 0009:00:00.0: AER: enabled with IRQ 63
[   11.067593] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[   11.189702] tegra194-pcie 140a0000.pcie: host bridge /pcie@140a0000 ranges:
[   11.196889] tegra194-pcie 140a0000.pcie:       IO 0x002a100000..0x002a1fffff -> 0x002a100000
[   11.205584] tegra194-pcie 140a0000.pcie:      MEM 0x3528000000..0x352fffffff -> 0x0040000000
[   11.214273] tegra194-pcie 140a0000.pcie:      MEM 0x3240000000..0x3527ffffff -> 0x3240000000
[   11.329092] tegra194-pcie 140a0000.pcie: Link up
[   11.334891] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[   11.508476] pcieport 0008:00:00.0: Adding to iommu group 10
[   11.514418] pcieport 0008:00:00.0: PME: Signaling with IRQ 61
[   11.520578] pcieport 0008:00:00.0: AER: enabled with IRQ 61
附上Jetson主机上设备树反编译生成的文件
device-tree.txt (428.0 KB)
error.txt (4.7 KB)
Sorry for the late response.
