Jetson Orin NX PCIe Compliance Test: Unable to Switch from Gen2 to Gen3 on M.2 NVMe Interface
Hi NVIDIA Team,
We are performing PCIe TX compliance testing on a custom carrier board with a Jetson Orin NX module and have encountered an issue similar to the one reported in this thread:
Hardware and Software Environment:
  • Module: Jetson Orin NX
  • Carrier board: Custom design
  • Interface: M.2 PCIe interface for NVMe SSD
  • Software: Jetson Linux R36 (JetPack 6.x)
  • PCIe power-down patch: disable-power-down.diff has been applied, rebuilt, flashed, and verified in the running kernel.
  • Reference document: Jetson Orin NX Series and Jetson Orin Nano Series Tuning and Compliance Guide, DA-11267-001 v1.3
Issue Description:
When a normal NVMe SSD is connected to the M.2 slot, the PCIe link can successfully operate at Gen3/Gen4 speeds.
However, when we replace the SSD with a PCIe compliance test fixture to perform TX electrical testing, we encounter the following issue:
  1. The PCIe controller can enter compliance mode and output the Gen1 (2.5 GT/s) compliance pattern.
  2. We can successfully switch from Gen1 to Gen2 (5 GT/s) using the test fixture.
  3. However, subsequent attempts to switch to Gen3 (8 GT/s) are unsuccessful. The TX output remains at Gen2 (5 GT/s).
  4. The issue persists even though the disable-power-down.diff patch has been applied.
Since the interface can successfully operate at Gen3/Gen4 speeds with a normal NVMe SSD, we suspect that the issue may be related to the PCIe compliance test mode, PHY configuration, or compliance pattern switching mechanism rather than the normal PCIe link training process.
Questions:
  1. Is there any known issue with switching from Gen2 to Gen3 compliance patterns on Jetson Orin NX with Jetson Linux R36?
  2. Besides applying disable-power-down.diff, are there any additional patches, device tree settings, or PCIe PHY configurations required for Gen3 TX compliance testing?
  3. Does the Gen3 compliance pattern switching depend entirely on the mode pulse received by the PCIe RX lane, or are there any software or register-level conditions that must be satisfied?
  4. Are there specific registers we can read to determine why the PCIe PHY remains at Gen2 instead of switching to Gen3? In particular, are there any recommended registers for checking LTSSM, compliance mode status, or Gen3 preset configuration?
  5. Is there a recommended debug procedure or way to enable additional PCIe controller/PHY debug logs to investigate this issue?
  6. Has NVIDIA reproduced or resolved the similar issue reported in the forum thread linked above?
We would appreciate any guidance on identifying the root cause and enabling Gen3 TX compliance testing.
Thank you for your support.
~1111
What is the speed of this NVMe got when it is on NV devkit?
