Hello NVIDIA Team,
We are facing a power-on issue with our Jetson Orin NX 8gb.
We are using a 12 V, 5 A power supply.
Current behavior:
- When we press and hold the power button, the Jetson powers ON and the cooling fan starts.
- As soon as we release the power button, the Jetson immediately turns OFF.
- The Jetson does not remain powered ON after releasing the button.
Troubleshooting already performed:
We moved the same Jetson Orin NX module with the cooling fan to another carrier board, but the same issue occurs on the second carrier board as well.
We would like to know:
- What could cause the Jetson to remain ON only while the power button is held?
- Which power-sequencing signals should we check, such as POWER_EN, SYS_RESET, SHUTDOWN_REQ** or other related signals?
- What voltage/state should these signals have during the power-on sequence?
- Can Force Recovery Mode be used to verify whether the Orin NX module is functioning correctly?
- Are there any additional hardware diagnostic procedures recommended by NVIDIA for this behavior?
