Jetson orin nx 系列板子 开启pwm 并 设置周期/占空比 失败
验证主板:
JETSON-ORIN-NX-16G-DEV-KIT
打开pwm:
sudo /opt/nvidia/jetson-io/jetson-io.py
选择 pwm7 (32)
save and reboot to reconfigure
设置周期,占空比 ,启用
# 1. 导出 pwmchip3 的 0 号通道
sudo sh -c ‘echo 0 > /sys/class/pwm/pwmchip3/export’
2. 设置 2Hz 周期 (500,000,000 ns)
sudo sh -c ‘echo 500000000 > /sys/class/pwm/pwmchip3/pwm0/period’
3. 先将占空比设为 0(防止配置过程中报错)
sudo sh -c ‘echo 0 > /sys/class/pwm/pwmchip3/pwm0/duty_cycle’
4. 再设置为你想要的占空比(例如 50%,即 250,000,000 ns)
sudo sh -c ‘echo 250000000 > /sys/class/pwm/pwmchip3/pwm0/duty_cycle’
5. 使能输出
sudo sh -c ‘echo 1 > /sys/class/pwm/pwmchip3/pwm0/enable’
验证:
无示波器,因此使用串口助手验证
目前验证的方式(rk3588的板子也是这么验证的,验证通过了):
  1. 上位机PWM(引脚15)→ 下位机E9
  2. 串口连接下位机,115200查看日志
  3. 观察 [PPS] 日志频率是否为2Hz(每秒2条)
**验证结果:**设置了pwm和没设置pwm 以及周期,占空比 改变, 串口日志的频率没有发生任何改变
Hi 2904298469,
Could you refer to Unable to generate PWM with Nvidia Jetson AGX Orin Development Kit - #6 by KevinFFF for the steps to enable PWM output?
Please share the result of ls -l /sys/class/pwm on your board.
Have you also tried if it could work with other frequency (e.g. 10kHz, 100000ns)
