Jetson Orin NX spec sheet differs from measurements
I measured two of your Jetson Orin NX modules, and got significantly different measurements than what is marked on your spec sheet drawing regarding height dimensions. I measured the height of the two highest components to be 3.8 and 2.8 mm as in the picture below
On the spec sheet below, the highest component is marked max 5.08mm, which differs 1,2mm from my measurement. Can the component really have this much tolerance?
What is also the area marked as blue on the step model and spec sheet (image below), which height is 4.08mm? It is not found on the physical module.
The 3D STP file includes component tolerances. It also accounts for alternative parts and their tolerances.
