Jetson Orin NX T801 flash/USB problem
you are right . it’s invalid.
I am actually not sure what you are talking about in this part.
I can’t flash through ssh anymore (must be through USB). I am getting the following error:
There is nothing called “flashed through ssh”. Jetson flash process is always relying on USB connection + recovery mode. Other things are probably not really flashing…
sudo BOOTDEV=nvme0n1p1 ./flash.sh --no-flash jetson-agx-orin-devkit-as-nx-16gb nvme0n1p1
Your flash command is also a wrong one which I really don’t know why you are using this…
Please check the quick start guide for the correct flash command.
The history you should also explain is how did you come up with this flash command…
