Jetson Orin NX USB0 Host Mode issue (Use USB Mux)
We have developed a new custom board based on the Jetson Orin NX.
We encountered an issue on this custom board and would like to request a solution.
This is an issue related to the USB0 Host Mode. We noticed that there is a similar topic to ours, but we are inquiring because our configuration is slightly different
( How to use USB0 as OTG in Device and Host Mode without changing device tree after flashing? )
Regarding our USB implementation, we have mapped the USB0 and USBSS0 ports as follows:
USB0 is designed through a USB MUX, splitting it into an OTG-only Device mode port (USB-C) and a Host-only port (internal connector). (The host port uses a constant +5V without a load switch.)
The USB-C type is used purely as a USB 2.0 port utilizing only the form factor, without USB-PD.
The issue is as follows: After flashing, if we disconnect the USB cable from the OTG port and connect a USB tester to the Host port (USB30A1) for testing, it indicates that the USB signal is not connected (non-functional).
When we debug the board and pull VBUS_EN0 LOW, the USB on the Host port works normally. (This is not a signal integrity issue.) ("To be exact, the issue is that the Host port is operating as OTG, which is contrary to our intended purpose.)
It appears to be a firmware/software-related issue with the USB0 Host operation. As we are hardware engineers and lack expertise in the source code, if any code modification is necessary, could you please guide us in detail—including the directory paths and the specific files/functions we need to change?
We have converted the flashed DTB file back into a DTS file and attached it to this post for your reference. (Since the DTS file could not be uploaded directly, we have converted it into a TXT file and attached it.)
kernel_tegra234-p3768-0000+p3767-0000-nv.txt (273.7 KB)
Below is the list of what we have tested so far:
  1. ports {
    				usb2-0 {
    					status = "okay";
    					//mode = "otg";
    					mode = "host";
    					vbus-supply = <0xf9>;
    					usb-role-switch;
  2. usb@3550000 {
    			compatible = "nvidia,tegra234-xudc";
    			reg = <0x00 0x3550000 0x00 0x8000 0x00 0x3558000 0x00 0x8000>;
    			reg-names = "base\0fpci";
    			interrupts = <0x00 0xa6 0x04>;
    			clocks = <0x03 0x109 0x03 0x10c 0x03 0x113 0x03 0x110>;
    			clock-names = "dev\0ss\0ss_src\0fs_src";
    			interconnects = <0x57 0x4c 0x58 0x57 0x4d 0x58>;
    			interconnect-names = "dma-mem\0write";
    			iommus = <0xf1 0x0f>;
    			power-domains = <0x03 0x0b 0x03 0x0a>;
    			power-domain-names = "dev\0ss";
    			nvidia,xusb-padctl = <0xfa>;
    			dma-coherent;
    			//status = "okay";
    			status = "disabled";
    			phys = <0xfb 0xfc>;
    			phy-names = "usb2-0\0usb3-0";
We are using Jetpack 7.2.1 and Jetson Linux R39.2.1.
Thank you!
apply all the changes you mentioned here and also remove the “usb-role-switch” in your device tree.
also want to clarify. How are you updating device tree here?
The dtb that uses for flash is not going to work after you boot.
We access the Jetson OS, extract the DTB file from the /boot/dtb directory, and convert it into a DTS file for modification.
Once modifications are complete, we convert the DTS file back into a DTB file and overwrite it in the same directory…
Shouldn’t we extract the DTB file from the /boot/dtb directory on the Jetson OS, modify it, and overwrite it?
From what we’ve tried, changing mode=‘otg’ to mode=‘host’ causes the flashing to fail.
For reference, the flash command I use is as follows:
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 \
  -c tools/kernel_flash/flash_l4t_t234_nvme.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" \
  --showlogs --network usb0 jetson-orin-nano-devkit internal
The method to update sounds correct to me.
Removing the ‘usb-role-switch’ entry seems to have resolved the issue.
