Jetson Orin NX will continue to reboot. I can’t even flash it.
I tried flashing Jetpack 5.1.2, 5.1.3, 6.0 using SDK Manager but failed.
I’ve looked through the relevant forums and got the logs thinking that maybe UART communication can fix the problem, but I’m not sure.
I also see a red LED light on power connection.
Thank you for your response.
I solved the flashing issue today.
The problem was ssh-keygen -t dsa.
At ~/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/ota_tools/version_upgrade/ota_make_recovery_img_dtb.sh
ssh-keygen -t dsa -N “” -f “${_initrd_dir}/${ssh_config_dir}/ssh_host_dsa_key” >/dev/null 2>&1;check_error
I commented out that command and the flashing was successful.
I recently upgraded ssh to 9.8 and I expect that’s the problem.
