When I use YOLOV11 environment on Jetson and use YOLO’s built-in onnx to engine file, I get an error message saying “Attributeerror: module” tensorrt “has no attrivute” __version __ ". My environment: jetson linux36.2,jetpack6.0DP ,python3.10,torch2.2.0,torchvision0.17.1, Can use trtexec tool to convert file format, but cannot use YOLO for engine file inference
In addition, I am using the Conda virtual environment
As JetPack 6 DP is a preview software, could you upgrade the environment to any GA version and try it again?
Thank you, do you mean I use jetpack 6.0 or 6.1?
Thank you very much for your prompt answer. If I have any new questions, can I continue to consult with you?
You can file a topic anytime but is your issue fixed after upgrading to JetPack 6.0GA or 6.1GA?
Thank you. When I was trying to install Jetpack 6.0, I encountered a compilation error while uninstalling the built-in OpenCV and installing OpenCV with CUDA. Therefore, I am not sure if this issue still exists. Here, I would like to ask a question. If I do not uninstall the built-in OpenCV and install OpenCV with CUDA, but instead create a virtual environment and install Torch, can I use “print (torch. CUDA. is-available ())” in Python in the virtual environment to get “True”? If possible, I will not try to install OpenCV with CUDA again
Support yes, you can still use GPU within the virtual environment.
You can check the below topic to get a PyTorch prebuilt with CUDA support:
