Jetson Orin Series Super Mode
We have design custom carrier board for Jetson Orin NX.
According to super mode support we kept following provisions in our circuit.
  1. +19V supply voltage feed to SOM.
  2. MODULE_ID (217) pin kept floating.
  3. Power mode selected to MAX_SUPER mode.
Jetson Orin NX works perfecctly fine in normal operational mode.
So just tried to test it in Super mode and trying check that maximum how much power it can consume from supply?
We run CPU and GPU stress test.
While doing that we observed that maximum wattage is not going beyond 25W.
We are expecting it should reach to maximum 40W but its not going beyond 25W.
For MAX_SUPER (40W) mode do we need to some device tree changes?
Please guide us on this query.
How did you enable the super mode?
Thanks a lot for reply.
As per super mode requirement.
  1. There is MODULE_ID (217) pin is there which is usually connected to the ground (pulled low).That pin we kept it floating.
  2. Commonly we give nominal +5V voltage supply to SOM but here we kept provision to give more than +5V supply to the SoM. (not more than +19V).
  3. In power mode selection we choose MAX_SUPER mode.
I think these are things are require to configure SoM in super mode.
  1. In power mode selection we choose MAX_SUPER mode.
No, I mean how did you flash your board?
Usually we flash Orin NX using SDK Mananger.
With host machine of Ubuntu 20.04 and Jetpack 6.2.1
Sdkmanager does not flash super mode by default. Only manual flash command would do that.
