The desktop cannot be displayed after power on。
I’ve reinstalled the system,But the situation has not changed,I can use it by ssh,but it ‘s show me the “‘DISPLAY’ environment variable not set… skipping “。
Who can tell me what I should do
What do you want to do here? Fix the display issue or something else?
And I want to know if my device is broken
Are you using a native DP monitor or some adapter/converter cable?
it’s a converter,DP to HDMI
Please try to test native DP monitor.
OK, I’ll try it. Thanks
Your adapter may under support after next release. Which we add DP++ support.
