I followed “Jetson Orin No monitor, VNC only splash screen until monitor connected” article and Youtube video to run Orin without monitor.
First, I was able to start udrcd on Orin, start urdc on Windows 11, connect to Orin, and display the Orin screen on Windows 11. It was great because I couldn’t do it with VNC.
However, if you unplug the HDMI cable from Orin, Orin’s screen displayed in Windows 11 will not be updated.
Also, I set xorg.conf according to the article, but Orin seems to be running, but it is not displayed on Windows 11. I tried both when Orin was started with an HDMI cable connected and when it was started without an HDMI cable connected, but neither was displayed.
I reluctantly flash it again and use it. It’s very time consuming.
Jetpack is 5.1.1.
I just want to use Orin monitorless, please let me know if there is anything wrong with my usage of urdc.
Hello and welcome to the NVIDIA forums. Your topic belongs in the Jetson OrIn category, I will go ahead and move it over for you.
Best,
T
You would need to connect to a display for using VNC. Please refer to steps in
VNC without display - #3 by DaneLLL
