Jetson orion nano 8GB DK Falshing failed
Hi I have jetson orion nano 8GB DK. I am getting flash failure.
I use Micro SD card. Settings are going into Automatic mode. Not sure why I am not able to see Manul.
Steps.
1-installed sdkmanager and has jetpack6
2-able to see the orion after putting in recvoery mode(with jumper cable)
3-USB connected
4-Put power and it goes Automatic configuration
5-Selcted Sd Card.
6-Flashing failes
I have ubuntu 22.04 machine
ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 450000
17:40:26 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 460000
17:40:26 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 470000
17:40:27 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 480000
17:40:28 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 490000
17:40:29 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 500000
17:40:30 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 510000
17:40:31 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 520000
17:40:32 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 530000
17:40:33 ERROR: Flash Jetson Linux - flash: 540000
17:40:33 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 550000
17:40:34 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 560000
17:40:34 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 570000
17:40:36 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 580000
17:40:36 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 590000
17:40:36 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 600000
17:40:37 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 610000
flashing-error.log (8.3 KB)
Please put the zip file from SDK Manager here.
@DaveYYY here it is
SDKM_logs_JetPack_6.0_(rev._1)_Linux_for_Jetson_Orin_Nano_modules_2024-05-31_10-34-22_ismail.zip (256.4 KB)
thanks
Next what I did,
download jetPack 5 to upgrade firmware, now I can see the firmware is updated. When booted I got screen resolution problem. I just try jetpack6 again but failed again.
Will try to complete these steps
need to make QSPI update part.
after upgrade of firmwar I tried with sdkmanager jetP6 only flashing and here the zip logs
SDKM_logs_JetPack_6.0_(rev._1)_Linux_for_Jetson_Orin_Nano_modules_2024-05-31_19-19-04_ONLY-FLASH.zip (1.0 MB)
Is your SD card 64GB or larger?
It was 32G, I switched to 64 and failed again, but click Retry and this time everything worked.
Problem resolved
