Jetson OS flash failed
Apt repository check failure (1. sudo -S apt-get update && sudo -S apt-get check; 2. dpkg --audit).
E: Failed to fetch http://realsense-hw-public.s3.amazonaws.com/Debian/apt-repo/dists/focal/InRelease 403 Forbidden [IP: 3.5.70.81 80]
E: The repository ‘http://realsense-hw-public.s3.amazonaws.com/Debian/apt-repo focal InRelease’ is not signe
I have an Ubuntu 20.04 , Host machine.
I initially got this error while flashing my Jetson to deprecate from Jetpack 6 to Jetpack 5.1.3 . It failed the check , I clicked on skip check and then after the necessary packages were downloaded , while preparing the os , i got error again , I have attached the logs for reference. Could the problem be because i am using an AMD based host machine
SDKM_logs_JetPack_5.1.4_Linux_for_Jetson_Orin_Nano_[8GB_developer_kit_version]_2024-12-09_12-29-08.zip (92.5 KB)
Hi
Please refer to related link to fix the issue.
