Jetson Power Issue
My jetson stopped working suddenly, when I plug in the power adaptor there is no response in the power led light and not even the fan is working. This issue has happened before too but it automatically started within an hour, but this time it has been more than 24hrs it’s still not working.
Which Jetson platform you’re using?
If you’re using Jetson Naon, please refer to below:
Guidance to tell if you are using a NV developer kit - Jetson & Embedded Systems / Jetson Nano - NVIDIA Developer Forums
Debug tips when you hit any issue (fail to boot/ keep reboot …etc) - Jetson & Embedded Systems / Jetson Nano - NVIDIA Developer Forums
We are using Jetson orin nano(8gb)
Movnig to Jetson Orin Nano forum.
Please try to put the device into recovery mode and use the SDK Manager to perform the full flash.
When I plug in the power adapter, there is no response from the power LED light, and even the fan doesn’t start. That’s why I can’t put the device into recovery mode or use the SDK Manager to perform a full flash.
