Hello
here the dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.253-tegra (nvidia@ubuntu) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #7 SMP PREEMPT Fri Feb 25 03:47:02 PST 2022
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00800000@92ca9000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57624 r8192 d32488 u98304
[ 0.000000] pcpu-alloc: s57624 r8192 d32488 u98304 alloc=24*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt tegra_fbmem=0x800000@0x92ca9000 is_hdmi_initialised=1 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29784(90%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3560004K/4159488K available (15358K kernel code, 2956K rwdata, 6724K rodata, 8640K init, 921K bss, 124348K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f80000 ( 15360 KB)
[ 0.000000] .rodata : 0xffffff8008f80000 - 0xffffff8009620000 ( 6784 KB)
[ 0.000000] .init : 0xffffff8009620000 - 0xffffff8009e90000 ( 8640 KB)
[ 0.000000] .data : 0xffffff8009e90000 - 0xffffff800a173008 ( 2957 KB)
[ 0.000000] .bss : 0xffffff800a173008 - 0xffffff800a259574 ( 922 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000009] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.009783] Console: colour dummy device 80x25
[ 0.014433] console [tty0] enabled
[ 0.017948] bootconsole [uart8250] disabled
[ 0.022277] kmemleak: Kernel memory leak detector disabled
[ 0.022305] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[ 0.022326] pid_max: default: 32768 minimum: 301
[ 0.022788] Security Framework initialized
[ 0.023104] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.023119] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.024280] ftrace: allocating 47182 entries in 185 pages
[ 0.196448] sched-energy: CPU device node has no sched-energy-costs
[ 0.196527] ASID allocator initialised with 65536 entries
[ 0.236040] tegra-id: chipid=22117.
[ 0.236071] tegra-id: opt_subrevision=0.
[ 0.236095] Tegra Speedo/IDDQ fuse revision 4
[ 0.236105] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.236115] Tegra: CPU Process ID 0, SoC Process ID 0, GPU Process ID 0
[ 0.236127] Tegra: CPU Speedo Value 2038, SoC Speedo Value 1941, GPU Speedo Value 2027
[ 0.236138] Tegra: CPU IDDQ Value 2016, SoC IDDQ Value 2248, GPU IDDQ Value 2645
[ 0.236165] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 0
[ 0.236185] DTS File Name: /home/nvidia/JetsonNano/linux_kernel_4.9.253/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/jetson_nano_devboard.dts
[ 0.236206] DTB Build time: Feb 7 2022 06:40:08
[ 0.285337] CPU1: Booted secondary processor [411fd071]
[ 0.317245] CPU2: Booted secondary processor [411fd071]
[ 0.349204] CPU3: Booted secondary processor [411fd071]
[ 0.349294] Brought up 4 CPUs
[ 0.349355] SMP: Total of 4 processors activated.
[ 0.349372] CPU features: detected feature: 32-bit EL0 Support
[ 0.349646] CPU: All CPU(s) started at EL2
[ 0.349677] alternatives: patching kernel code
[ 0.358143] devtmpfs: initialized
[ 0.393907] Initilizing CustomIPI irq domain
[ 0.394259] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.394301] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.405779] pinctrl core: initialized pinctrl subsystem
[ 0.406411] OS set in device tree is not L4T.
[ 0.406876] regulator-dummy: no parameters
[ 0.407164] Initializing plugin-manager
[ 0.407331] Plugin module not found
[ 0.407534] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[ 0.408077] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[ 0.408793] node /plugin-manager/fragment@5 match with board 3449-0000-200
[ 0.409396] node /plugin-manager/fragement@7 match with odm-data enable-pmic-wdt
[ 0.409634] node /plugin-manager/fragement@8 match with odm-data enable-pmic-wdt
[ 0.409926] node /plugin-manager/fragement@9 match with board <3448-0000-300
[ 0.413489] NET: Registered protocol family 16
[ 0.417657] pstore: using zlib compression
[ 0.418162] console [pstore-1] enabled
[ 0.418177] pstore: Registered ramoops as persistent store backend
[ 0.418195] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.437356] cpuidle: using governor menu
[ 0.440418] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.442128] vdso: 2 pages (1 code @ ffffff8008f87000, 1 data @ ffffff8009e94000)
[ 0.442173] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.445864] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.448051] Serial: AMBA PL011 UART driver
[ 0.448601] tegra_powergate_init: DONE
[ 0.448636] DTS File Name: /home/nvidia/JetsonNano/linux_kernel_4.9.253/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/jetson_nano_devboard.dts
[ 0.448671] DTB Build time: Feb 7 2022 06:40:08
[ 0.450402] Tegra reboot handler registered.
[ 0.454934] iommu: Adding device tegra-carveouts to group 0
[ 0.455106] platform tegra-carveouts: domain=ffffffc0f9b943d8 allocates as[0]=ffffffc0f94180a8
[ 0.455485] iommu: Adding device smmu_test to group 1
[ 0.455549] platform smmu_test: domain=ffffffc0f9b94618 allocates as[0]=ffffffc0f9418110
[ 0.456393] mc: mapped MMIO address: 0xffffff8008041000 -> 0x70019000
[ 0.456475] mc: mapped MMIO address: 0xffffff8008067000 -> 0x7001c000
[ 0.456549] mc: mapped MMIO address: 0xffffff800807b000 -> 0x7001d000
[ 0.456572] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.456606] mc-err: mcerr ops are set to t21x
[ 0.467228] iommu: Adding device 70090000.xusb to group 2
[ 0.467543] iommu: Adding device 70006000.serial to group 3
[ 0.467621] platform 70006000.serial: domain=ffffffc0f940ecd8 allocates as[0]=ffffffc0f9418178
[ 0.468078] iommu: Adding device 70006040.serial to group 4
[ 0.468361] iommu: Adding device 70006200.serial to group 5
[ 0.468569] iommu: Adding device sound to group 6
[ 0.468628] platform sound: domain=ffffffc0f9497258 allocates as[0]=ffffffc0f94181e0
[ 0.469207] iommu: Adding device 7000d400.spi to group 7
[ 0.469559] iommu: Adding device 7000d600.spi to group 8
[ 0.469861] iommu: Adding device 70410000.spi to group 9
[ 0.470180] iommu: Adding device 50000000.host1x to group 10
[ 0.470474] iommu: Adding device 54080000.vi to group 11
[ 0.470880] iommu: Adding device 54600000.isp to group 12
[ 0.471157] iommu: Adding device 54680000.isp to group 13
[ 0.471445] iommu: Adding device tegradc.0 to group 14
[ 0.471515] platform tegradc.0: domain=ffffffc0f94a3198 allocates as[0]=ffffffc0f9418248
[ 0.475735] platform tegradc.0: IOVA linear map 0x0000000092ca9000(800000)
[ 0.476147] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.476508] iommu: Adding device tegradc.1 to group 15
[ 0.476591] platform tegradc.1: domain=ffffffc0f94a33d8 allocates as[0]=ffffffc0f94182b0
[ 0.480798] platform tegradc.1: IOVA linear map 0x0000000092ca9000(800000)
[ 0.481208] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.481509] iommu: Adding device 54340000.vic to group 16
[ 0.481730] iommu: Adding device 544c0000.nvenc to group 17
[ 0.481949] iommu: Adding device 54500000.tsec to group 18
[ 0.482162] iommu: Adding device 54100000.tsecb to group 19
[ 0.482373] iommu: Adding device 54480000.nvdec to group 20
[ 0.482578] iommu: Adding device 54380000.nvjpg to group 21
[ 0.483660] iommu: Adding device 546c0000.i2c to group 22
[ 0.484003] iommu: Adding device 57000000.gpu to group 23
[ 0.484097] platform 57000000.gpu: domain=ffffffc0f95493d8 allocates as[0]=ffffffc0f9418318
[ 0.484153] platform 57000000.gpu: domain=ffffffc0f95493d8 allocates as[1]=ffffffc0f9418380
[ 0.484208] platform 57000000.gpu: domain=ffffffc0f95493d8 allocates as[2]=ffffffc0f94183e8
[ 0.484261] platform 57000000.gpu: domain=ffffffc0f95493d8 allocates as[3]=ffffffc0f9418450
[ 0.485172] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.485214] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.485239] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.485258] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.485275] tegra-pmc: ### PMC reset status reg: 0x3
[ 0.537522] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.537556] tegra-pmc: Clear bootloader IO dpd settings
[ 0.537588] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.537669] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.537998] iommu: Adding device 70012000.se to group 24
[ 0.538779] iommu: Adding device 7000c000.i2c to group 25
[ 0.539045] iommu: Adding device 7000c400.i2c to group 26
[ 0.539316] iommu: Adding device 7000c500.i2c to group 27
[ 0.539583] iommu: Adding device 7000c700.i2c to group 28
[ 0.539847] iommu: Adding device 7000d000.i2c to group 29
[ 0.540108] iommu: Adding device 7000d100.i2c to group 30
[ 0.540447] iommu: Adding device sdhci-tegra.0 to group 31
[ 0.540527] platform sdhci-tegra.0: domain=ffffffc0f9558558 allocates as[0]=ffffffc0f94184b8
[ 0.541402] iommu: Adding device 700d0000.xudc to group 32
[ 0.544661] vdd-ac-bat: 5000 mV
[ 0.545054] vdd-5v0-sys: 5000 mV
[ 0.545771] vdd-5v0-hdmi: 5000 mV
[ 0.546214] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.546519] vdd-1v8-sys: 1800 mV
[ 0.546923] vdd-fan: 5000 mV
[ 0.547150] vdd-fan: supplied by vdd-5v0-sys
[ 0.547381] vdd-usb-vbus: 5000 mV
[ 0.547602] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.548009] vdd-usb-vbus2: 5000 mV
[ 0.582365] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.584660] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.586249] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.586627] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.594744] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.595133] SCSI subsystem initialized
[ 0.595380] libata version 3.00 loaded.
[ 0.595676] usbcore: registered new interface driver usbfs
[ 0.595772] usbcore: registered new interface driver hub
[ 0.595833] usbcore: registered new device driver usb
[ 0.599960] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.601529] random: fast init done
[ 0.604583] vdd-core: 600 <--> 1162 mV at 1125 mV
[ 0.605604] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.608634] vdd-ddr-1v1: 1150 mV
[ 0.612469] vdd-pre-reg-1v35: 1350 mV
[ 0.616471] vdd-1v8: 1800 mV
[ 0.620468] avdd-sys-1v2: 1200 mV
[ 0.624467] vdd-pex-1v0: 1050 mV
[ 0.625151] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[ 0.625710] max77620-ldo3: at 3100 mV
[ 0.628473] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[ 0.629007] max77620-ldo5: at 3100 mV
[ 0.629553] max77620-ldo6: at 2800 mV
[ 0.632501] avdd-1v05-pll: 1050 mV
[ 0.636467] avdd-io-hdmi-dp: 1050 mV
[ 0.639006] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.639357] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.639667] max77620 4-003c: max77620 probe successful
[ 0.642658] media: Linux media interface: v0.10
[ 0.642739] Linux video capture interface: v2.00
[ 0.643789] pps_core: LinuxPPS API ver. 1 registered
[ 0.643818] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.643859] PTP clock support registered
[ 0.646836] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.647739] Advanced Linux Sound Architecture Driver Initialized.
[ 0.648404] Bluetooth: Core ver 2.22
[ 0.648469] NET: Registered protocol family 31
[ 0.648485] Bluetooth: HCI device and connection manager initialized
[ 0.648512] Bluetooth: HCI socket layer initialized
[ 0.648531] Bluetooth: L2CAP socket layer initialized
[ 0.648568] Bluetooth: SCO socket layer initialized
[ 0.650421] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.650460] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.650522] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.650549] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.653731] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.655016] vdd-3v3-sys: 3300 mV
[ 0.655421] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.655495] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.656544] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.657000] vdd-3v3-sd: 3300 mV
[ 0.657451] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.658038] avdd-io-edp-1v05: 1050 mV
[ 0.658406] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.658613] vdd-usb-hub-en: 5000 mV
[ 0.658976] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.659939] camchar: rtcpu character device driver loaded
[ 0.660713] extcon-gpio-states extcon:extcon@1: Cable state:1, cable id:1
[ 0.662194] clocksource: Switched to clocksource arch_sys_counter
[ 0.704645] VFS: Disk quotas dquot_6.6.0
[ 0.704836] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.705374] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.705860] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.705919] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.706222] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.706248] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.706277] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.706331] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.706356] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.706388] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.706409] nvmap_page_pool_init: Total RAM pages: 1008785
[ 0.706426] nvmap_page_pool_init: nvmap page pool size: 126098 pages (492 MB)
[ 0.706630] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.706991] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.707921] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.716400] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.716875] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.717251] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.717546] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.717740] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.718039] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.718057] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[ 0.718561] NET: Registered protocol family 2
[ 0.719581] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.719818] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.720367] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.720545] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.720642] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.721072] NET: Registered protocol family 1
[ 0.721767] RPC: Registered named UNIX socket transport module.
[ 0.721793] RPC: Registered udp transport module.
[ 0.721809] RPC: Registered tcp transport module.
[ 0.721825] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.721849] PCI: CLS 0 bytes, default 64
[ 0.722084] Trying to unpack rootfs image as initramfs...
[ 1.023873] Freeing initrd memory: 6992K
[ 1.033654] host1x 50000000.host1x: initialized
[ 1.035622] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.039089] audit: initializing netlink subsys (disabled)
[ 1.039186] audit: type=2000 audit(0.883:1): initialized
[ 1.039897] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 1.050067] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.051627] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.052452] 9p: Installing v9fs 9p2000 file system support
[ 1.055808] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 241)
[ 1.055956] io scheduler noop registered
[ 1.056261] io scheduler cfq registered (default)
[ 1.059125] gic 702f9000.agic: GIC IRQ controller registered
[ 1.062113] iommu: Adding device 702ef000.adsp to group 33
[ 1.071538] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 1.071722] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 1.072423] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x8208410
[ 1.072452] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 1.074135] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 1.074322] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 1.074450] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 1.074670] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 1.074780] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 1.074899] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 1.075007] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 1.075118] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 1.075225] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 1.075331] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 1.081453] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 1.083225] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 1.085166] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 1.086542] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 1.086930] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 1.088225] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.088487] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=750000, max_bw=1500000
[ 1.088747] Adding domain tsec-pd to PM domain host1x-pd
[ 1.090819] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 1.091808] tsec 54500000.tsec: initialized
[ 1.093450] tsec 54100000.tsecb: initialized
[ 1.094219] Adding domain nvdec-pd to PM domain host1x-pd
[ 1.097463] nvdec 54480000.nvdec: initialized
[ 1.098591] Adding domain vic03-pd to PM domain host1x-pd
[ 1.098791] Adding domain msenc-pd to PM domain host1x-pd
[ 1.098967] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.102673] falcon 54340000.vic: initialized
[ 1.103966] falcon 544c0000.nvenc: initialized
[ 1.105321] falcon 54380000.nvjpg: initialized
[ 1.109833] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=97
[ 1.109905] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[ 1.109949] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[ 1.110057] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.110170] display board info: id 0x0, fab 0x0
[ 1.110280] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[ 1.110283] generic_infoframe_type: 0x87
[ 1.110313] tegra_cec 70015000.tegra_cec: probed
[ 1.110430] tegradc tegradc.0: DT parsed successfully
[ 1.110501] tegradc tegradc.0: Display dc.ffffff800ac00000 registered with id=0
[ 1.111071] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350781
[ 1.118732] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.119206] tegradc tegradc.0: probed
[ 1.125719] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[ 1.127328] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[ 1.127373] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.127881] kfuse 7000fc00.kfuse: initialized
[ 1.129564] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.130674] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.132374] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.132412] vdd-cpu: 708 <--> 1322 mV at 708 mV
[ 1.132961] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.134611] vdd-gpu: applied init 1000000uV constraint
[ 1.134642] vdd-gpu: 708 <--> 1323 mV at 997 mV
[ 1.135132] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.140304] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.140504] No Device Node present for smmu client: serial8250 !!
[ 1.140535] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.140628] iommu: Adding device serial8250 to group 35
[ 1.144550] console [ttyS0] disabled
[ 1.144721] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.614412] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.018961] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.146219] tegra_cec 70015000.tegra_cec: Can't find physical addresse.
[ 2.146225] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 2.423370] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.425386] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 2.531590] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 2.531600] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.531606] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 2.531610] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 2.531616] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.531664] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 2.531776] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.532029] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.532207] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 2.532235] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 2.532268] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 2.532290] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 2.532441] pci 0000:01:00.0: supports D1 D2
[ 2.532445] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.546298] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.546348] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 2.546354] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.546365] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[ 2.546386] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[ 2.546405] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.546415] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 2.546420] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.546427] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[ 2.546861] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.546867] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.546875] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 2.547011] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 3.556031] console [ttyS0] enabled
[ 3.556644] Console: switching to colour frame buffer device 240x67
[ 3.559474] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 3.559820] serial-tegra 70006200.serial: RX in PIO mode
[ 3.559910] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 3.560977] [drm] Initialized
[ 3.591849] brd: module loaded
[ 3.596036] tegradc tegradc.0: fb registered
[ 3.602217] loop: module loaded
[ 3.605469] tegra_profiler: version: 1.145, samples/io: 49/28
[ 3.607415] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mode.
[ 3.607458] tegradc tegradc.0: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_75m_150m
[ 3.607947] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[ 3.607957] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[ 3.641484] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 3.641506] tegra_profiler: auth: init
[ 3.642870] THERMAL EST: found 2 subdevs
[ 3.642876] THERMAL EST num_resources: 0
[ 3.642882] [THERMAL EST subdev 0]
[ 3.642888] [THERMAL EST subdev 1]
[ 3.643350] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 3.643352] THERMAL EST: thz register success.
[ 3.643567] THERMAL EST: end of probe, return err: 0
[ 3.644656] sd: No Scsi addr parsed to reserve index
[ 3.644688] hisi_sas: driver version v1.6
[ 3.650814] tegra-qspi 70410000.spi: Prod settings list not found
[ 3.651980] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 3.651989] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 3.663665] libphy: Fixed MDIO Bus: probed
[ 3.664336] tun: Universal TUN/TAP device driver, 1.6
[ 3.664339] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 3.665235] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 3.665237] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.665296] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 3.665298] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.665342] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 3.665346] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 3.665402] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 4.4.0-k
[ 3.665405] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[ 3.672790] r8168 0000:01:00.0: enabling device (0000 -> 0003)
[ 3.672824] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 3.687690] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 3.687756] r8168 Copyright (C) 2017 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 3.688408] PPP generic driver version 2.4.2
[ 3.688635] PPP BSD Compression module registered
[ 3.688639] PPP Deflate Compression module registered
[ 3.688681] PPP MPPE Compression module registered
[ 3.688687] NET: Registered protocol family 24
[ 3.688768] usbcore: registered new interface driver r8152
[ 3.688825] usbcore: registered new interface driver asix
[ 3.688884] usbcore: registered new interface driver ax88179_178a
[ 3.688924] usbcore: registered new interface driver cdc_ether
[ 3.688957] usbcore: registered new interface driver net1080
[ 3.688995] usbcore: registered new interface driver cdc_subset
[ 3.689032] usbcore: registered new interface driver zaurus
[ 3.689084] usbcore: registered new interface driver cdc_ncm
[ 3.689263] VFIO - User Level meta-driver version: 0.3
[ 3.690730] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.690761] ehci-pci: EHCI PCI platform driver
[ 3.690812] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 3.690824] ohci-pci: OHCI PCI platform driver
[ 3.690875] ohci-platform: OHCI generic platform driver
[ 3.693719] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 3.694364] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 3.695575] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f97b2000 id
[ 3.698073] usbcore: registered new interface driver uas
[ 3.698137] usbcore: registered new interface driver usb-storage
[ 3.698273] tegra-xusb 70090000.xusb: Firmware timestamp: 2020-07-31 09:33:12 UTC, Version: 50.26 release
[ 3.698345] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 3.698372] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 3.699147] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 3.699212] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 3.699671] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.699677] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.699682] usb usb1: Product: xHCI Host Controller
[ 3.699686] usb usb1: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[ 3.699690] usb usb1: SerialNumber: 70090000.xusb
[ 3.700019] usbcore: registered new interface driver usbserial
[ 3.700419] hub 1-0:1.0: USB hub found
[ 3.700464] hub 1-0:1.0: 5 ports detected
[ 3.701075] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 3.701087] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 3.701215] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 3.701323] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 3.701329] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.701333] usb usb2: Product: xHCI Host Controller
[ 3.701336] usb usb2: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[ 3.701339] usb usb2: SerialNumber: 70090000.xusb
[ 3.701841] hub 2-0:1.0: USB hub found
[ 3.701876] hub 2-0:1.0: 4 ports detected
[ 3.702911] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 3.702917] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 3.705341] tegra-xudc-new 700d0000.xudc: device count: 1
[ 3.706859] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 3.706871] tegra-xudc-new 700d0000.xudc: vbus state: 1
[ 3.706887] tegra-xudc-new 700d0000.xudc: device mode on: 0
[ 3.706915] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[ 3.706942] tegra-xudc-new 700d0000.xudc: active: 0 => 1
[ 3.707639] mousedev: PS/2 mouse device common for all mice
[ 3.707754] usbcore: registered new interface driver xpad
[ 3.802302] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 3.810450] usb usb2: usb_suspend_both: status 0
[ 3.835643] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 3.838261] rtc rtc1: alarm rtc device
[ 3.838284] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 3.838315] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 3.838973] i2c /dev entries driver
[ 3.841497] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.844244] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 3.844251] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 3.844744] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.844763] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 3.844772] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 3.844903] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.844913] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 3.844920] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 3.845062] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.845073] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 3.845078] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 3.845247] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 3.846093] tegra_aotag tegra-aotag: Registering sensor 0
[ 3.846144] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.846171] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.846225] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 3.846234] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 3.847405] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.847426] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[ 3.847626] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.847657] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[ 3.848190] parse_throttle_dt_data: Num cap clks = 6
[ 3.848197] parse_throttle_dt_data: clk=cclk_g type=2
[ 3.848210] parse_throttle_dt_data: clk=gpu type=4
[ 3.848237] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 3.848256] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 3.848278] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 3.848281] parse_throttle_dt_data: clk=emc type=3
[ 3.848795] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.848956] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.849193] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.850112] FAN dev name: pwm-fan
[ 3.850257] FAN:gpio request success.
[ 3.850325] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.850722] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 3.850933] pwm_fan_driver pwm-fan: fan tach request irq success
[ 3.850943] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.851053] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 3.851058] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 3.851063] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 3.851067] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 3.851071] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 3.851075] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 3.851080] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 3.851084] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 3.851088] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 3.851092] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 3.852340] device-mapper: uevent: version 1.0.3
[ 3.852958] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 3.858338] tegra210-cpufreq cpufreq: probe()...completed
[ 3.859085] sdhci: Secure Digital Host Controller Interface driver
[ 3.859086] sdhci: Copyright(c) Pierre Ossman
[ 3.859088] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.859575] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 3.859924] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 3.860046] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 3.864706] tegra-se 70012000.se: tegra_se_probe: complete
[ 3.865228] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.866373] usbcore: registered new interface driver usbhid
[ 3.866374] usbhid: USB HID core driver
[ 3.868515] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[ 3.868678] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 3.870700] nvpmodel: initialized successfully
[ 3.871768] usbcore: registered new interface driver snd-usb-audio
[ 3.871822] No Device Node present for smmu client: snd-soc-dummy !!
[ 3.871827] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 3.871845] iommu: Adding device snd-soc-dummy to group 36
[ 3.877301] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 3.893917] OPE platform probe
[ 3.894004] OPE platform probe successful
[ 3.894292] OPE platform probe
[ 3.894374] OPE platform probe successful
[ 3.910420] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 3.920661] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 3.920788] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 3.920909] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 3.921032] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 3.921155] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 3.921274] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 3.921399] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 3.921518] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 3.921639] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 3.921761] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 3.933325] u32 classifier
[ 3.933327] Actions configured
[ 3.933399] Initializing XFRM netlink socket
[ 3.934103] NET: Registered protocol family 10
[ 3.934903] NET: Registered protocol family 17
[ 3.934914] NET: Registered protocol family 15
[ 3.934986] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 3.935036] Bluetooth: RFCOMM socket layer initialized
[ 3.935045] Bluetooth: RFCOMM ver 1.11
[ 3.935049] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.935053] Bluetooth: HIDP socket layer initialized
[ 3.935071] 9pnet: Installing 9P2000 support
[ 3.935104] Key type dns_resolver registered
[ 3.938891] Registered cp15_barrier emulation handler
[ 3.938898] Registered setend emulation handler
[ 3.939942] registered taskstats version 1
[ 3.940522] Adding domain ve2-pd to PM domain host1x-pd
[ 3.940764] Adding domain ve-pd to PM domain host1x-pd
[ 4.026415] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 4.067653] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 4.067656] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.067659] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 4.067661] usb 1-2: Manufacturer: Generic
[ 4.071207] hub 1-2:1.0: USB hub found
[ 4.072279] hub 1-2:1.0: 4 ports detected
[ 4.117774] mmc0: hw tuning done ...
[ 4.117806] mmc0: new ultra high speed SDR104 SDHC card at address aaaa
[ 4.118077] mmcblk0: mmc0:aaaa SE32G 29.7 GiB
[ 4.121861] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 4.175030] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 4.209263] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 4.209267] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.209270] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 4.209272] usb 2-1: Manufacturer: Generic
[ 4.213307] hub 2-1:1.0: USB hub found
[ 4.215959] hub 2-1:1.0: 4 ports detected
[ 4.374250] usb 1-2.1: new high-speed USB device number 3 using tegra-xusb
[ 4.400656] usb 1-2.1: New USB device found, idVendor=2109, idProduct=2813
[ 4.400660] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.400662] usb 1-2.1: Product: USB2.0 Hub
[ 4.400664] usb 1-2.1: Manufacturer: VIA Labs, Inc.
[ 4.401754] hub 1-2.1:1.0: USB hub found
[ 4.402573] hub 1-2.1:1.0: 4 ports detected
[ 4.494250] usb 1-2.3: new low-speed USB device number 4 using tegra-xusb
[ 4.519166] usb 1-2.3: New USB device found, idVendor=17ef, idProduct=6019
[ 4.519171] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.519173] usb 1-2.3: Product: Lenovo USB Optical Mouse
[ 4.519176] usb 1-2.3: Manufacturer: Logitech
[ 4.522594] input: Logitech Lenovo USB Optical Mouse as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3:1.0/0003:17EF:6019.0001/input/input1
[ 4.522927] hid-generic 0003:17EF:6019.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech Lenovo USB Optical Mouse] on usb-70090000.xusb-2.3/input0
[ 4.638956] usb 2-1.1: new SuperSpeed USB device number 3 using tegra-xusb
[ 4.741604] usb 2-1.1: New USB device found, idVendor=2109, idProduct=0813
[ 4.741608] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.741611] usb 2-1.1: Product: USB3.0 Hub
[ 4.741613] usb 2-1.1: Manufacturer: VIA Labs, Inc.
[ 4.742580] hub 2-1.1:1.0: USB hub found
[ 4.742755] hub 2-1.1:1.0: 4 ports detected
[ 4.874243] usb 1-2.1.1: new low-speed USB device number 5 using tegra-xusb
[ 4.900619] usb 1-2.1.1: New USB device found, idVendor=04b3, idProduct=3025
[ 4.900623] usb 1-2.1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.900625] usb 1-2.1.1: Product: USB NetVista Full Width Keyboard
[ 4.900628] usb 1-2.1.1: Manufacturer: CHICONY
[ 4.904322] input: CHICONY USB NetVista Full Width Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1.1/1-2.1.1:1.0/0003:04B3:3025.0002/input/input2
[ 4.962639] hid-generic 0003:04B3:3025.0002: input,hidraw1: USB HID v1.10 Keyboard [CHICONY USB NetVista Full Width Keyboard] on usb-70090000.xusb-2.1.1/input0
[ 5.129476] Extcon AUX1(HDMI) enable
[ 5.133538] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 5.139936] tegradc tegradc.1: No lt-data, using default setting
[ 5.145950] tegradc tegradc.1: No hpd-gpio in DT
[ 5.150582] tegradc tegradc.1: DT parsed successfully
[ 5.155652] tegradc tegradc.1: Display dc.ffffff800d580000 registered with id=1
[ 5.162034] tegradc tegradc.0: nominal-pclk:148351648 parent:148350781 div:1.0 pclk:148350781 146868084~161703244
[ 5.168189] usb 2-1.1.4: new SuperSpeed USB device number 4 using tegra-xusb
[ 5.180961] tegradc tegradc.1: dpd enable lookup fail:-19
[ 5.183807] usb 2-1.1.4: New USB device found, idVendor=0bda, idProduct=8153
[ 5.183811] usb 2-1.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 5.183813] usb 2-1.1.4: Product: USB 10/100/1000 LAN
[ 5.183815] usb 2-1.1.4: Manufacturer: Realtek
[ 5.183818] usb 2-1.1.4: SerialNumber: 000001000000
[ 5.219283] tegradc tegradc.1: probed
[ 5.223151] tegradc tegradc.1: fb registered
[ 5.230538] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 5.237681] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 5.238363] isp 54600000.isp: initialized
[ 5.239294] isp 54680000.isp: initialized
[ 5.249510] last reset is due to software reset
[ 5.249512] KERNEL: PMC reset status reg: 0x3
[ 5.249575] BL: PMC reset status reg: 0x3
[ 5.249577] BL: PMIC poweroff Event Recorder: 0x0
[ 5.254172] clk_cbus_recalc_rate: no gbus parent
[ 5.254177] clk_cbus_round_rate: no gbus parent
[ 5.254203] clk_cbus_round_rate: no gbus parent
[ 5.254210] clk_cbus_recalc_rate: no gbus parent
[ 5.254314] clk_cbus_recalc_rate: no gbus parent
[ 5.254316] clk_cbus_round_rate: no gbus parent
[ 5.254318] clk_cbus_round_rate: no gbus parent
[ 5.254321] clk_cbus_recalc_rate: no gbus parent
[ 5.254334] tegra_dvfs: GPU-cap: registered
[ 5.254400] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 5.254402] tegra dvfs: vdd-core: nominal 1125mV, offset 600000uV, step 12500uV, scaling enabled
[ 5.254404] tegra dvfs: vdd-gpu: nominal 1078mV, offset 708000uV, step 10000uV, scaling enabled
[ 5.256058] tegra_dvfs: vdd-gpu-vts: registered
[ 5.256755] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[ 5.257374] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[ 5.257931] input: gpio-keys as /devices/gpio-keys/input/input3
[ 5.270778] usb 2-1.1.4: reset SuperSpeed USB device number 4 using tegra-xusb
[ 5.294076] tegra_rtc 7000e000.rtc: setting system clock to 2022-02-25 14:04:44 UTC (1645797884)
[ 5.295460] vi 54080000.vi: vi_probe: ++
[ 5.299674] vi 54080000.vi: initialized
[ 5.301787] vi 54080000.vi: subdev nvcsi--1 bound
[ 5.301998] mmcblk mmc0:aaaa: Card claimed for testing.
[ 5.302570] Disable partitions left on by BL
[ 5.302572] disb
[ 5.302611] bwmgr: missing cdev-type property
[ 5.302701] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 5.302708] DRAM derating cdev registered.
[ 5.303611] ALSA device list:
[ 5.303614] #0: tegra-hda at 0x70038000 irq 83
[ 5.303616] #1: tegra-snd-t210ref-mobile-rt565x
[ 5.362935] r8152 2-1.1.4:1.0 eth1: v2.09.00 (2017/08/21)
[ 5.362938] r8152 2-1.1.4:1.0 eth1: This product is covered by one or more of the following patents:
[ 5.457765] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 5.457842] tegradc tegradc.0: blank - powerdown
[ 5.503079] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 5.503081] Extcon AUX1(HDMI) disable
[ 5.530988] tegradc tegradc.0: unblank
[ 5.566847] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 5.566895] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 5.567880] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 5.602670] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 5.602672] Extcon AUX1(HDMI) enable
[ 5.618122] tegradc tegradc.0: sync windows ret = 247
[ 5.728282] tegradc tegradc.1: blank - powerdown
[ 5.735009] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 5.735011] Extcon DP: HPD disabled
[ 5.735012] hpd: hpd_switch 0
[ 5.735015] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 5.735022] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 5.735026] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 5.780607] extcon-disp-state extcon:disp-state: cable 51 state 1
[ 5.780608] Extcon HDMI: HPD enabled
[ 5.780619] tegradc tegradc.0: hdmi: plugged
[ 5.803869] Freeing unused kernel memory: 8640K
[ 5.834607] Root device found: mmcblk0p1
[ 5.842022] Found dev node: /dev/mmcblk0p1
[ 5.881616] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 5.893577] Rootfs mounted over mmcblk0p1
[ 5.928670] Switching from initrd to actual rootfs
[ 6.184026] x_tables: disagrees about version of symbol audit_log_start
[ 6.192685] x_tables: Unknown symbol audit_log_start (err -22)
[ 6.214314] systemd[1]: Failed to insert module 'ip_tables': Invalid argument
[ 6.238726] cgroup: cgroup2: unknown option "nsdelegate"
[ 6.262471] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 6.288982] systemd[1]: Detected architecture arm64.
[ 6.336488] systemd[1]: Set hostname to <videosystems-jn>.
[ 6.468699] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 6.488427] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 6.660941] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.671552] systemd[1]: Created slice User and Session Slice.
[ 6.682323] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.692134] systemd[1]: Created slice System Slice.
[ 6.701904] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.711777] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 6.723046] systemd[1]: Reached target Slices.
[ 6.732437] systemd[1]: Reached target Swap.
[ 6.826000] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 7.398869] systemd-journald[2053]: Received request to flush runtime journal from PID 1
[ 8.302424] nvgpu: disagrees about version of symbol cdev_add
[ 8.313241] nvgpu: Unknown symbol cdev_add (err -22)
[ 8.320689] nvgpu: disagrees about version of symbol cdev_init
[ 8.320692] nvgpu: Unknown symbol cdev_init (err -22)
[ 8.320708] nvgpu: disagrees about version of symbol cdev_del
[ 8.320710] nvgpu: Unknown symbol cdev_del (err -22)
[ 8.328199] random: crng init done
[ 8.328201] random: 7 urandom warning(s) missed due to ratelimiting
[ 8.505045] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 8.505067] cpu-throttle-alert cooling device registered.
[ 8.505248] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 8.505263] gpu-throttle-alert cooling device registered.
[ 8.505420] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 8.505433] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 8.505448] hot-surface-alert cooling device registered.
[ 8.667957] nvgpu: disagrees about version of symbol cdev_add
[ 8.678747] nvgpu: Unknown symbol cdev_add (err -22)
[ 8.681964] nvgpu: disagrees about version of symbol cdev_init
[ 8.681967] nvgpu: Unknown symbol cdev_init (err -22)
[ 8.681984] nvgpu: disagrees about version of symbol cdev_del
[ 8.681986] nvgpu: Unknown symbol cdev_del (err -22)
[ 9.553333] using random self ethernet address
[ 9.559481] using random host ethernet address
[ 10.607361] overlay: disagrees about version of symbol dentry_open
[ 10.624006] overlay: Unknown symbol dentry_open (err -22)
[ 10.667614] Mass Storage Function, version: 2009/09/11
[ 10.667620] LUN: removable file: (no medium)
[ 10.682759] using random self ethernet address
[ 10.710683] using random host ethernet address
[ 11.131551] rndis0: HOST MAC e6:ef:39:87:5e:94
[ 11.131620] rndis0: MAC e6:ef:39:87:5e:95
[ 11.132096] usb0: HOST MAC e6:ef:39:87:5e:96
[ 11.132125] usb0: MAC e6:ef:39:87:5e:97
[ 11.132155] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 11.136402] l4tbr0: port 1(rndis0) entered blocking state
[ 11.136407] l4tbr0: port 1(rndis0) entered disabled state
[ 11.136969] device rndis0 entered promiscuous mode
[ 11.145619] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 11.149849] l4tbr0: port 2(usb0) entered blocking state
[ 11.149854] l4tbr0: port 2(usb0) entered disabled state
[ 11.150029] device usb0 entered promiscuous mode
[ 11.155297] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 11.217136] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 11.218161] eth0: 0xffffff800a49c000, 00:e0:4c:68:01:8e, IRQ 406
[ 11.268073] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 11.279003] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 11.295514] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 11.347427] android_work: did not send uevent (0 0 (null))
[ 11.385186] android_work: sent uevent USB_STATE=CONNECTED
[ 11.671317] zram: Added device: zram0
[ 11.671867] zram: Added device: zram1
[ 11.675493] zram: Added device: zram2
[ 11.676140] zram: Added device: zram3
[ 11.708110] zram0: detected capacity change from 0 to 518500352
[ 12.294778] Adding 506344k swap on /dev/zram0. Priority:5 extents:1 across:506344k SS
[ 12.298786] zram1: detected capacity change from 0 to 518500352
[ 12.309029] Adding 506344k swap on /dev/zram1. Priority:5 extents:1 across:506344k SS
[ 12.312654] zram2: detected capacity change from 0 to 518500352
[ 12.323248] Adding 506344k swap on /dev/zram2. Priority:5 extents:1 across:506344k SS
[ 12.326558] zram3: detected capacity change from 0 to 518500352
[ 12.337006] Adding 506344k swap on /dev/zram3. Priority:5 extents:1 across:506344k SS
[ 12.581229] android_work: sent uevent USB_STATE=DISCONNECTED
[ 12.616353] android_work: sent uevent USB_STATE=CONNECTED
[ 12.638738] configfs-gadget gadget: high-speed config #1: c
[ 12.638770] tegra-xudc-new 700d0000.xudc: ep 5 (type: 3, dir: in) enabled
[ 12.638786] tegra-xudc-new 700d0000.xudc: ep 3 (type: 2, dir: in) enabled
[ 12.638802] tegra-xudc-new 700d0000.xudc: ep 2 (type: 2, dir: out) enabled
[ 12.638890] tegra-xudc-new 700d0000.xudc: ep 9 (type: 3, dir: in) enabled
[ 12.638906] tegra-xudc-new 700d0000.xudc: ep 7 (type: 2, dir: in) enabled
[ 12.638922] tegra-xudc-new 700d0000.xudc: ep 4 (type: 2, dir: out) enabled
[ 12.638957] tegra-xudc-new 700d0000.xudc: ep 15 (type: 3, dir: in) enabled
[ 12.638976] tegra-xudc-new 700d0000.xudc: ep 11 (type: 2, dir: in) enabled
[ 12.638997] tegra-xudc-new 700d0000.xudc: ep 6 (type: 2, dir: out) enabled
[ 12.639035] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[ 12.639213] android_work: sent uevent USB_STATE=CONFIGURED
[ 14.330264] r8168: eth0: link up
[ 14.330320] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 15.397274] overlay: disagrees about version of symbol dentry_open
[ 15.403525] overlay: Unknown symbol dentry_open (err -22)
[ 15.885658] tegradc tegradc.0: blank - powerdown
[ 15.934801] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 15.934803] Extcon AUX1(HDMI) disable
[ 15.955275] tegradc tegradc.0: unblank
[ 15.991273] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 15.991353] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 15.992363] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 16.027159] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 16.027162] Extcon AUX1(HDMI) enable
[ 16.042629] tegradc tegradc.0: sync windows ret = 246
[ 18.132585] tegradc tegradc.0: blank - powerdown
[ 18.175965] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 18.175967] Extcon AUX1(HDMI) disable
[ 18.196447] tegradc tegradc.0: unblank
[ 18.199546] overlay: disagrees about version of symbol dentry_open
[ 18.199550] overlay: Unknown symbol dentry_open (err -22)
[ 18.232432] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 18.232521] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 18.233542] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 18.268438] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 18.268441] Extcon AUX1(HDMI) enable
[ 18.283815] tegradc tegradc.0: sync windows ret = 246
[ 18.404060] l4tbr0: port 1(rndis0) entered blocking state
[ 18.404066] l4tbr0: port 1(rndis0) entered forwarding state
[ 18.404182] IPv6: ADDRCONF(NETDEV_UP): l4tbr0: link is not ready
[ 18.404199] IPv6: ADDRCONF(NETDEV_CHANGE): l4tbr0: link becomes ready
[ 21.018503] tegradc tegradc.0: blank - powerdown
[ 21.067469] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 21.067471] Extcon AUX1(HDMI) disable
[ 21.089473] tegradc tegradc.0: unblank
[ 21.124745] overlay: disagrees about version of symbol dentry_open
[ 21.124749] overlay: Unknown symbol dentry_open (err -22)
[ 21.125822] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 21.126207] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 21.128674] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 21.166269] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 21.166272] Extcon AUX1(HDMI) enable
[ 21.178909] tegradc tegradc.0: sync windows ret = 247
[ 23.970277] tegradc tegradc.0: blank - powerdown
[ 24.012338] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 24.012340] Extcon AUX1(HDMI) disable
[ 24.032732] tegradc tegradc.0: unblank
[ 24.069614] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 24.069701] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 24.070728] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 24.105734] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 24.105737] Extcon AUX1(HDMI) enable
[ 24.120949] tegradc tegradc.0: sync windows ret = 246
[ 24.438957] tegradc tegradc.0: blank - powerdown
[ 24.487736] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 24.487739] Extcon AUX1(HDMI) disable
[ 24.508050] tegradc tegradc.0: unblank
[ 24.544065] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 24.544134] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 24.545145] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 24.583923] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 24.583926] Extcon AUX1(HDMI) enable
[ 24.595407] tegradc tegradc.0: sync windows ret = 247
Only to confirm my situation. I cross compile on a Host (Ubuntu 18). I have a demoboard of a Jetson Nano running. I sympli copy the compiled Image with scp on the Jetson /boot directory. I never copied the modules. If I only compile the Image without any changes, all goes well. If I change to enable kernel debug GDB, I see this behaviour.
K.R.
