You can try to set your device into the MAXN mode before running the test
On the Orin device, rebooting is required when setting a different power mode.
However, there is an interactive checker to confirm the rebooting process which might make the script look like frozen.
To manually set the MAXN mode can avoid the issue.
Please give it a check to see if this works for your problem.
$ sudo nvpmodel -m 0
NVPM WARN: Golden image context is already created
NVPM WARN: Reboot required for changing to this power mode: 0
NVPM WARN: DO YOU WANT TO REBOOT NOW? enter YES/yes to confirm:
