I used SDK Manager on Ubuntu 20.04.5 to flash Jetson Linux 35.2.1 and Jetpack 5.1 to AGX Orin. All but the Multimedia installation completed successfully. Here is the terminal log:
20:05:19 ERROR: Flash Jetson Linux - flash: [ 6.2565 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
20:05:19 ERROR: Flash Jetson Linux - flash: [ 6.2573 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
20:05:19 ERROR: Flash Jetson Linux - flash: [ 6.2581 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
20:05:19 ERROR: Flash Jetson Linux - flash: [ 6.2587 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
20:17:29 SUMMARY: Flash Jetson Linux - flash: Install completed successfully.
20:17:40 ERROR: nc: connect to 192.168.55.1 port 22 (tcp) failed: Connection refused
20:17:40 ERROR: Cannot connect to the device via SSH. Check the user name and password, and make sure that SSH service is running on the device.
20:18:01 ERROR: nc: connect to 192.168.55.1 port 22 (tcp) failed: Connection refused
20:18:01 ERROR: Cannot connect to the device via SSH. Check the user name and password, and make sure that SSH service is running on the device.
20:18:23 ERROR: nc: connect to 192.168.55.1 port 22 (tcp) failed: Connection refused
20:18:23 ERROR: Cannot connect to the device via SSH. Check the user name and password, and make sure that SSH service is running on the device.
20:18:45 ERROR: nc: connect to 192.168.55.1 port 22 (tcp) failed: Connection refused
20:18:45 ERROR: Cannot connect to the device via SSH. Check the user name and password, and make sure that SSH service is running on the device.
20:19:07 ERROR: nc: connect to 192.168.55.1 port 22 (tcp) failed: Connection refused
20:19:07 ERROR: Cannot connect to the device via SSH. Check the user name and password, and make sure that SSH service is running on the device.
20:19:29 ERROR: nc: connect to 192.168.55.1 port 22 (tcp) failed: Connection refused
20:19:29 ERROR: Cannot connect to the device via SSH. Check the user name and password, and make sure that SSH service is running on the device.
20:20:59 ERROR: Connection to 192.168.55.1 22 port [tcp/ssh] succeeded!
20:21:01 ERROR: command terminated with error
20:21:02 ERROR: command terminated with error
20:21:03 ERROR: command terminated with error
20:21:04 ERROR: command terminated with error
20:21:05 ERROR: command terminated with error
20:21:19 SUMMARY: DateTime Target Setup - target: Install completed successfully.
20:26:56 SUMMARY: CUDA Runtime - target: Install completed successfully.
20:29:24 SUMMARY: CuDNN Runtime - target: Install completed successfully.
20:31:36 SUMMARY: TensorRT Runtime - target: Install completed successfully.
20:34:30 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta) - target: Install completed successfully.
20:34:37 ERROR: Multimedia API - target: E: Unable to correct problems, you have held broken packages.
20:34:49 ERROR: Multimedia API - target: E: Unable to correct problems, you have held broken packages.
20:35:10 ERROR: Multimedia API - target: E: Unable to correct problems, you have held broken packages.
20:35:10 ERROR: Multimedia API - target: Unhandled error when running sudo -E apt-get -y --allow-downgrades install /opt/nvidia/deb_repos/nvidia-l4t-jetson-multimedia-api_35.2.1-20230121191456_arm64.deb: E: Unable to correct problems, you have held broken packages.;
20:35:10 ERROR: Multimedia API - target: command terminated with error
20:35:10 SUMMARY: Multimedia API - target: First Error: Installation failed. . Your device BSP image version is incompatible with the software version you are trying to install. Please flash your device with the right BSP version and try to re-install.
20:40:47 SUMMARY: CUDA Toolkit for L4T - target: Install completed successfully.
20:43:30 SUMMARY: cuDNN on Target - target: Install completed successfully.
20:46:54 SUMMARY: TensorRT on Target - target: Install completed successfully.
20:47:49 SUMMARY: OpenCV Runtime - target: Install completed successfully.
20:49:15 SUMMARY: OpenCV - target: Install completed successfully.
20:49:35 SUMMARY: CuPVA Runtime - target: Install completed successfully.
20:51:06 SUMMARY: VPI Runtime - target: Install completed successfully.
20:52:39 SUMMARY: VPI on Target - target: Install completed successfully.
and screen capture:
