Using latest Jetson SDK Manager command line to attempt to flash Jetson Tx2 with jetpack v3.3.3 but having issues:
command:
sdkmanager --cli install --logintype devzone --product Jetson --version 3.3.3 --targetos Linux --host --target P3310-1000 --flash all
result: (using ‘…’ to denote left out debug)
Server data loaded successfully
jetson version 3.3.3 does not support Linux target OS on P33310-1000
Available options are:
Jetson 4.5.1
Jetson 4.5
However when I run the SDK Manager with the GUI I can use the Jetson jetpack V3.3.3 just fine and flash the tx2
Any suggestions?
