Jetson shuts down when running classification_interactive
I’m going through the Nvidia Getting Started With AI on Jetson Nano. I’m in the image classification section (having successfully navigated through Hello Camera).
I am using the dlinano image. I have connected to the Nano using port 8888. The Jupyter notebook classification_interactive comes up just fine, and I can run through each of the cells just fine. The interactive tool comes up with no problem, and the camera (a USB Logitech) is initialized and ready to go. I can take 30 shots of a thumbs up, and 30 of a thumbs down.
When I click the train button, I do not get the expected training data. Within a minute or two the Nano powers down. Then I receive a Server Connection Error.
Fortunately, when I boot the whole thing back up, and go back into the Jupyter lab, it kept my settings so I am able to re-run. But it does the same thing every time.
Hi.
Shutdown is usually related to the power starvation.
Please read this topic for the recommendation of Nano’s power supply:
https://devtalk.nvidia.com/default/topic/1048640/jetson-nano/power-supply-considerations-for-jetson-nano-developer-kit/
And could you set the device into 5W mode to see if helps first?
sudo nvpmodel -m 1
Thank-you sir. That did the trick.
Oops: I don’t know if you’re a sir or a ma’am. My bad.
I had the same problem and setting the nvpmodel helped
Hi guys,
I’m having almost same problem, but I’m pretty sure is no power issue because I’m using a 5V 30W power supply. Is any way (log file for example) for checking why this is powering off suddenly? It’s always happen when I run some inference models, and I only did some software changes, hardware hasn’t changed.
Best regards!
