Jetson Sponsorship Request – Odonata: AI drone for bark beetle detection on Orin NX 16GB (Jugend forscht 2027, Germany)
Hi everyone,
I’m Stefanos, a high-school student from Ismaning, Germany. In 2026 I won 1st place in Math/Computer Science at the Bavarian state final of Jugend forscht junior, the junior track of Germany’s national youth science competition, with SignAI, an AI sign-language translator (signai.dev, Stefanos0710 (Stefanos) · GitHub ).
For Jugend forscht 2027 I’m building Odonata, an autonomous drone that has to detect and avoid obstacles fully on board.
Why: Odonata is meant to fly over spruce forests, spot signs of bark beetle infestation with on-board AI and log climate data such as temperature and humidity along the way, so foresters can find infested trees earlier. Bark beetles are one of the biggest threats to Germany’s forests. There’s often no mobile signal in the forest, so all inference has to run on the drone itself.
Current setup: DarwinFPV F411 flight controller with a Raspberry Pi Zero 2 W as companion computer. This is far too slow for real perception.
Planned setup:
  • Jetson Orin NX 16GB on a compact drone carrier
  • 2× depth camera + 1× RGB camera
  • on-board obstacle detection and local path planning
  • 700 g fixed-mass budget, JetPack 6.2 in Super mode with active cooling
Why the Orin NX 16GB: it has enough compute to run depth processing and a detector in parallel with the planner. The 16 GB also leaves headroom for experiments with larger models. An Orin Nano would be my fallback, but it limits how much runs at the same time.
My question: does NVIDIA have a way to support student competition projects like this one, with a module, a loan or an education discount? I’d document the whole build here in the forum, open source everything and present NVIDIA as the compute partner at the competition.
Here you can find more about the prototype: GitHub - Stefanos0710/Odonata: A fully autonomous drone for precise indoor navigation and worldwide remote control. · GitHub . I’m happy to answer technical questions.
Thanks! Stefanos
Hello @stefanoskoufogazos!
Based on the title and content of your topic, it looks like it may receive better visibility and feedback in a different category. We took the liberty of moving it for you.
If this was an incorrect assessment, please send me a direct message.
Disclaimer: this moderation suggestion and message were generated with AI assistance.
Thanks for your interest in NVIDIA Jetson! Unfortunately, we’re unable to fulfill hardware sponsorship requests at this time — the volume of requests we receive makes it impossible to support them individually, and we do not have a grant program to direct you to at this time.
We’d encourage you to explore purchasing Jetson through our authorized distributors, or check out the NVIDIA Jetson store for current options.
We hope you find a path to get your project off the ground, and we’d love to see what you build with the Jetson community.
