Jetson storage service does not start after jetson machine restart
hi ,The machine I used is jetson agx orin, which mounted an external 1T hard disk and started the Jetson-Storage service. In most cases, Jetson-Storage did not start when restarting, please ask if you have ever had this situation
Thanks for reporting the issue. I will check and feedback later.
Can you share log of below command line after reboot the Orin device?
$ systemctl status jetson-storage
$ sudo systemctl restart jetson-storage
storage_1.txt (2.7 KB)
I don’t remember this happening when there were no containers running on the machine. I currently have multiple docker containers running on my machine
We are checking the jetson-storage issue. We found USB SSD driver up is a little bit slow after reboot. Can you have a try with NVMe for Orin AGX: Storage — Metropolis on Jetson documentation 0.1.0 documentation ?
