I upgraded to Jetpack 6 by following these instructions:
https://docs.nvidia.com/jetson/jetpack/install-setup/index.html#upgrade-jetpack
After I rebooted it the boot screen comes up but then no login and the screen remains blank.
I have a Macbook Pro. Installed docker container to flash it but can’t even login. Please guide.
I am using Devkit Orin AGX 64GB
Hi hitesh.patel2,
What’s the Jetpack version in use before upgrade?
Could you share the serial console log for further check?
You can refer to the following instruction to capture serial console log.
NVIDIA Jetson Orin - Serial Console (ridgerun.com)
system
Closed
5
