Jetson T4000 SPI2 使用自定义cs脚无法控制管脚
dtc -I fs -O dts /proc/device-tree > /tmp/dt.log
dt.log (404.3 KB)
关键设备树
&spi1 {
	status = "okay";
	num-cs = <2>;
	cs-gpios = <0>,
			<&gpio_main TEGRA264_MAIN_GPIO(Y, 1)>;
	spi@0 {
		/* chip select 0 */
		compatible = "tegra-spidev";
		reg = <0x0>;
		spi-max-frequency = <50000000>;
	spi@1 {
		/* chip select 0 */
		reg = <0x1>;
我使用以下指令分别测试cs0与cs1,cs0管脚控制正常,cs1没有任何作用。
./spidev_test -D /dev/spidev1.0 -s 1000000 -p "\xaa\x55"
./spidev_test -D /dev/spidev1.1 -s 1000000 -p "\xaa\x55"
Hi hansguo,
Are you using the devkit or custom board for T4000?
What’s the exact SPI interface are you using? c6c0000.spi?
If so, there should be only one hardware-based CS available to be used on this bus.
I’m using the custom board for T4000.
root@thor:~# cat /etc/nv_tegra_release
R38 (release), REVISION: 4.0, GCID: 43443517, BOARD: generic, EABI: aarch64, DATE: Wed Dec 31 00:15:19 UTC 2025
KERNEL_VARIANT: oot
TARGET_USERSPACE_LIB_DIR=nvidia
TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia
INSTALL_TYPE=openrm
spi@c6c0000
Can I use the GPIO as a second CS pin?
You can use software-based CS by specifying cs-gpios properties in device tree.
Please refer to following thread for the example:
Enable more CS pins for SPI - Cannot find /Linux-for-Tegras directory - #51 by Ppovoa
You need to configure it as GPIO/Output/Drive 1 in pinmux spreadsheet before use.
Thanks!It works!
  • Configure it as GPIO/Output/Drive 1 in pinmux spreadsheet
  • set cs-gpios in dtsi
&spi1 {
	status = "okay";
	num-cs = <2>;
	cs-gpios = <0>,
			<&gpio_main TEGRA264_MAIN_GPIO(Y, 1) GPIO_ACTIVE_LOW>;
