Hi team,
Could you tell me What is the USB Type C PD enumeration happening in thor kit? what all power profiles does it support. I understood that the max voltage and current of the load switch AOZ13937DI-01 is 32V and 8A. This means as per EPR standard, The Thor kit will sink 28v/5A (140W). This should be the max power suitable for this Load switch.
If i am running full load of the SoM, i.e 130W, which power profile does the Thor kit sink? I have attached a screenshot of GUI attached where i observed that the kit consumed around 152W.
Could you tell me which power profile was sunk by the Thor kit in order to consume 152W?
please refer to
The Module TDP Budget is 130W for AGX Thor.
When power goes beyond this, it would trigger the throttling mechanism.
That’s for Module alone. I am asking about the total dev kit power (SoM module+Carrier peripherals). It shows that it consumed around 152W, How can it consume 152W when the PD sink power itself is 140W? (28V/5A)
I believe the power value you are referencing is the Inst (EDP peak), which can naturally be higher than the Avg (EDP continuous) power. The average power will also vary depending on your specific workload.
Furthermore, if you are powering the system via USB-C, the available power will likely be lower than what the Micro-Fit connector can provide. As a result, the system could be more susceptible to power-related resets. Users must develop and manage their workloads while fully accounting for the limitations of their specific USB-C power supply.
okay. Also, what should be the current from the source regulator for SYS_VIN_HV section of the SoM? How much it would consume during full load operating condition? The input voltage that i am planning to provide is 15V.
Please refer to the Jetson Thor Series Modules Data Sheet for the maximum power; the estimated input current is (I=P/V), excluding efficiency and design margin.
Could you clarify what you mean by “full load”? Simultaneously maximizing all engines could require significantly more power than a typical workload.
Normal workloads should remain near the selected power-mode limit; users can balance the workload if power consumption is too high.
