Jetson THOR HDMI 4K30 D0/D1/D2 Mask Test fail
Hi Sir
HDMI 4K30fps Signal Integrity D0/D1/D2 Mask Test fail, can we modify parameters of register to meet criterion?
4K30Hz_Fail.pdf (7.1 MB)
Currently, there is no method to do SI test. Please wait for our update for the document.
Hi Wayne
So NV HDMI SI test document will include the tuning registers?
If the HDMI layout fully complies with the requirements in the Jetson Thor Design Guide, the interface is expected to meet the applicable SI criteria using the default transmitter settings. Therefore, the register setting and tuning procedure are not publicly documented.
Please review the HDMI layout again and confirm that there are no violation of the Design Guide requirements. In particular, please carefully check the D0 lane, as the test reports shows significantly more mask violations on D0 than on D1 and D2.
Please also verify whether there are any lane specific differences in routing, differential impedance, insertion loss, via usage, connector routing, or ESD protection components.
Thank you,
Hi
HDMI 4K60 D0/D1/D2 VSwing still fail, showing the same trend as the 4K30fps test results. Could we try adjusting the HDMI Output Swing or Drive Strength? It need’s NV help.
Regarding the layout, we have followed the layout guidelines as closely as possible.
Thanks a lot.
4K60Hz_Fail.pdf (4.7 MB)
Could you please share the HDMI-related of your carrier board schematic, covering the signal path from the Jetson Thor module connector to the HDMI connector?
Please also confirm whether any of the following devices are installed on the HDMI clock or data lanes:
  • ESD protection devices
  • Common-mode devices
  • Series resistors, test points, or other components that may create a trace stub
Thank you,
Hi
Please refer the schematic, thanks.
HDMI Schematic.pdf (110.8 KB)
Thank you for providing the schematic.
The components most likely to affect the HDMI compliance results are the 5.6Ω series resistors on each TMDS signals and the common-mode chokes L1401- L1404.
As described in the Design Guide, any components added to the HDMI signal paths must be selected and optimized to minimize their impact on signal quality, and the complete channel must meet the applicable HDMI requirements.
Thank you,
