[Jetson Thor] HDMI Output Support on DP0, DP1, and DP2 with JetPack 7.2.1
We are developing a custom carrier board for Jetson AGX Thor and are currently reviewing the HDMI output interface design.
Our current custom carrier board is designed to use DP0 for HDMI output.
However, we are also considering using DP2 instead of DP0, as this would reduce the HDMI signal trace length on the PCB by approximately 33 mm.
During our review, we found the following NVIDIA forum discussion:
DP2 configured as HDMI shows no display
In this discussion, NVIDIA mentioned that DP2 and DP3 had issues related to DCE firmware and hotplug handling, and that these issues might be fixed in JetPack 7.2.
We are currently using JetPack 7.2.1 (L4T R39.2.1).
Before finalizing our hardware design, we would like to clarify the following points.
Q1. HDMI Output Using DP0
Can DP0 be configured and used for native HDMI output on Jetson Thor?
Are there any hardware or software limitations when using DP0 for HDMI output compared to DP1, which is used for HDMI on the EVK?
Q2. HDMI Output Using DP1
Is it necessary or recommended to use DP1 for HDMI output, as implemented on the EVK?
Q3. HDMI Output Using DP2
Can DP2 be configured and used for native HDMI output with JetPack 7.2.1 (L4T R39.2.1)?
We are particularly interested in using DP2 because it would allow us to reduce the HDMI signal trace length on the PCB by approximately 33 mm compared to DP0.
Q4. Software Configuration and Support Limitations
If DP0 or DP2 can be used for HDMI output, could you please clarify the following?
  • Are DCB configuration changes sufficient, or are additional modifications required?
  • Are any changes required to the pinmux, HDMI DDC, HPD, or other firmware settings?
  • Have the previously reported DP2/DP3 DCE firmware and hotplug issues been resolved in JetPack 7.2.1?
  • Has native HDMI output on DP0 and DP2 been validated, and is it officially supported in L4T R39.2.1?
We would appreciate your confirmation on whether DP0, DP1, and DP2 can all support native HDMI output, and whether NVIDIA recommends a specific port assignment for custom carrier board designs.
This information will help us finalize our hardware configuration before completing the PCB layout.
Thank you for your support.
The error for multiple HDMI on Thor turns out to be just tool issue but not an issue in driver.
With this new dcb tool to set DCB image (DP0/DP1/DP2 to HDMI)
and also the pinmux setting for HPD pins, multiple HDMI would work.
Thank you for your prompt support.
