Hi
We are running the PCIe TX SI test, but no signal generate from Thor when connect test fixture. Do we need other PCIe SI test command or tool can into PCIe compliance test mode?
Leif
Hi
Leif
Extra patch to disable power down and SSC are needed.
4c85b37.diff (4).zip (426 Bytes)
bcdf3d3.diff (4).zip (412 Bytes)
after applying these, run
cat /sys/kernel/debug/bpmp/debug/pcie/enable_compliancy
Hi WayneWWW,
would like to know where to apply 4c85b37.diff??
can not find pcie-common.dtsi in JP7.2.1
Regards
That is bpmp dtb but not kernel dtb.
