Hi Nvidia team,
In Thor Pinmux file v1.7 , D49/D48 default usage set to SF_1_CLK
but there is no SF_PCIE_CLK_P in customer usage column
is it ok ???
Regards
Does this affect any functionality on your side? or you just want to report a problem you saw in spreadsheet?
Hi WayWWW,
Still in pinmux setting stage, and we don’t know this is a bug or not ?
Just want to know may this difference cause any unexpected status ?
Regards
All the PCIe related pinmux settign could be directly set by using the dtsi file.
I have notified internal team to check the spreadsheet. You could ignore spreadsheet issue and configure the dtsi file for pinmux directly.
