We’re running a fleet of Jetson AGX Thor modules on CTI Gauntlet (AGX301-class) carriers and are hitting a reproducible driver-level deadlock: the devfreq GPU load-sampling path appears to deadlock against the RM API lock, wedging every GPU-touching process in uninterruptible (D) state. The only recovery is a hard reboot. Posting in case it’s already tracked, and to see if there’s a fix or a fuller workaround.
Platform / versions
Module: Jetson AGX Thor
Carrier: CTI Gauntlet + Thor AGX
L4T/BSP: R38 (release), REVISION 4.0 (JetPack 7.1), OpenRM (INSTALL_TYPE=openrm)
Kernel: 6.8.12-tegra #1 SMP PREEMPT
Rootfs: Ubuntu 24.04
GCID: 43443517
Access: headless / remote only (SSH, Tailscale, RustDesk on a virtual dummy display); no physical display
Workload: CUDA application — no camera/Argus, no display output
We cannot move to R39.2 / JetPack 7.2 yet, and the R39.2 release notes do not list this issue as fixed.
Symptom
Under normal CUDA load the system intermittently enters a state where every GPU-touching process (our app, the compositor, RustDesk display access) blocks in D-state. The hung-task detector reports blocked tasks at the 120s threshold and re-reports at ~241s / ~362s / ~483s as the wedge persists. Observed on multiple units.
Deadlock chain (as we understand it)
The blocked kworker is the devfreq monitor, stuck acquiring the RM API write lock:
devfreq_monitor (kworker, D-state)
-> [governor_pod_scaling / devfreq load sampling]
-> rm_pmu_perfmon_get_load
-> rmapiLockAcquire
-> os_acquire_rwlock_write
(never acquired -> task wedged)
Once devfreq_wq is wedged, other GPU-touching tasks queue behind the same lock and also go D-state.
Earlier in the same boot (~14.4s) we also see an RM control failure that may indicate RM/DCE instability preceding the hang:
NVRM: rpcRmApiControl_dce: ... NV_ERR_GENERIC
This looks like the same lock-acquisition chain reported in other Thor R38/JP7 threads here on the forums, where setting devfreq governors to performance did not eliminate the deadlock.
Questions
- Is this devfreq ↔
rmapiLockAcquiredeadlock a known issue, and is there a bug ID to track? - Is a fix confirmed or planned for any JetPack 7.x release? (Not listed as fixed through R39.2 / JP7.2.)
- Any recommended workaround beyond clock-pinning that more fully avoids the trigger on R38.4 / JP7.1, given we can’t upgrade yet?
Happy to attach full dmesg, the complete hung-task stack traces, nvpmodel -q, jetson_clocks --show, and per-unit kernel build details. Let me know what’s most useful.
