We are investigating an intermittent shutdown/reboot issue on a Jetson Thor-based platform during heavy AI inference workloads.
The issue is most frequently observed when running RAG workloads that generate very large Qwen prefill operations. Just before the event, SGLang logs show large #new-token prefill batches (for example, 8192 tokens followed by an additional batch of roughly 1,000-4,000 tokens). The system then becomes unreachable and reboots.
Some observations:
- The issue appears to correlate with the largest prefill workload bursts rather than steady-state token generation.
- We have observed the 3.3 V rail dropping around the time of the shutdown/reboot event.
- The issue becomes significantly harder to reproduce when:
- Hybrid search is disabled, reducing the number of large prefills.
- The platform is operated in a 90 W (or lower) power mode.
- Smaller inference workloads and normal chatbot interactions can run for extended periods without issue.
- Standard Linux logs, kernel logs, and application logs have not revealed any software faults, crashes, OOM events, thermal events, or other indicators that explain the shutdown/reboot. The absence of useful diagnostic information in the logs makes this appear more consistent with a hardware or power-related event.
Has anyone observed similar shutdown/reboot behavior on Jetson Thor during large-context LLM inference workloads?
Any guidance would be appreciated.
