Hi NVIDIA team,
I am bringing up a 1280x800@30fps YUV422-8bit camera on Jetson Thor T5000 with Jetson Linux r38.4, but this specific mode cannot stream successfully.
System Configuration
Platform: Jetson Thor T5000
Jetson Linux: r38.4
CSI-2: 4 data lanes
Deserializer: MAX96712
Serializer: MAX96701
Data format: YUV422 8-bit / YUYV
Target mode: 1280x800@30fps
CSI interface: serial_a
Port index: 0
Brick: Brick 0 / PORT_A
VC mapping: VC0-VC3 → video0-video3
Background
The current driver supports three modes:
mode0: 1920x1080 YUYV
mode1: 1280x800 YUYV
mode2: 3840x2162 YUYV
I have verified that mode0 and mode2 can stream correctly. Only mode1, which is 1280x800 YUYV, fails to output frames.
The following command times out and no frame is captured:
v4l2-ctl -d /dev/video0 \
--set-fmt-video=width=1280,height=800,pixelformat=YUYV \
--stream-mmap --stream-to=/dev/null
Device Tree Configuration
The related device-tree mode settings are:
mode0 {
phy_mode = "DPHY";
num_lanes = "4";
pix_clk_hz = "71280000";
mclk_khz = "0";
serdes_pix_clk_hz = "350000000";
discontinuous_clk = "no";
cil_settletime = "0";
dpcm_enable = "false";
dynamic_pixel_bit_depth = "16";
csi_pixel_bit_depth = "16";
mode_type = "yuv";
pixel_phase = "yuyv";
active_w = "1920";
active_h = "1080";
line_length = "2200";
embedded_metadata_height = "0";
vc_id = "0";
mode1 {
phy_mode = "DPHY";
num_lanes = "4";
pix_clk_hz = "74250000";
mclk_khz = "0";
mode_type = "yuv";
active_w = "1280";
active_h = "800";
line_length = "1280";
vc_id = "0";
mode2 {
phy_mode = "DPHY";
num_lanes = "4";
pix_clk_hz = "285384000";
mclk_khz = "0";
mode_type = "yuv";
active_w = "3840";
active_h = "2162";
line_length = "3840";
vc_id = "0";
dmesg:
[ 3663.404118] [RCE] CSI port AB
[ 3663.404121] [RCE] AFE_HFGAIN_IO0_A=7
[ 3663.404123] [RCE] AFE_HFGAIN_IO1_A=7
[ 3663.404127] [RCE] AFE_HFGAIN_CLK_A=7
[ 3663.404130] [RCE] AFE_HFGAIN_IO0_B=7
[ 3663.404133] [RCE] AFE_HFGAIN_IO1_B=7
[ 3663.404135] [RCE] AFE_HFGAIN_CLK_B=7
[ 3666.119971] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 3668.679949] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 3671.208097] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
trace:
trace.log (39.2 KB)
kworker/6:1-129 [006] … 716.486663: rtcpu_unknown: tstamp:736853704514 id:0x000a000b len:4 data:00 00 00 00
kworker/6:1-129 [006] … 716.486663: rtcpu_unknown: tstamp:736853719755 id:0x000f0001 len:8 data:00 00 00 00 00 00 00 00
kworker/6:1-129 [006] … 716.486663: rtcpu_vinotify_event: tstamp:736861815764 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:736851612655 data:0x0000000031000002
kworker/6:1-129 [006] … 716.486664: rtcpu_vinotify_event: tstamp:736889536347 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:736889486421 data:0x0000000000000010
kworker/6:1-129 [006] … 716.542540: rtcpu_vinotify_event: tstamp:736898931375 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:736889486437 data:0x0000000800000000
Question
Since mode0 and mode2 work with the same driver and CSI link, but mode1 fails, I suspect the issue may be related to the mode1 timing or device-tree parameters.
Could you please advise how to debug this issue on Jetson Thor?
