Jetson T5000 QSFP28 (MGBE) Throughput Below Expected Line Rate
Document purpose : Problem description for NVIDIA Developer Forum submission
Date : 2026-06-18
Author : (fill in your name / organization)
FORUM SUBJECT LINE
Jetson T5000 QSFP28 (MGBE) throughput far below line rate β ~12.7 Gbps single
stream, ~3 Gbps per stream with 4 parallel flows
We are benchmarking QSFP28 optical Ethernet on NVIDIA Jetson T5000 and observe
throughput well below the expected 25 Gbps per port.
| Test scenario | Observed throughput | Expected |
| Single TCP stream (1 link) | ~12.6β12.7 Gbps | ~25 Gbps (QSFP28) |
| Four parallel TCP streams (4 links) | ~2.8β3.5 Gbps per stream | ~25 Gbps per link |
| (~12 Gbps aggregate) | independently
The combined behavior suggests an aggregate bottleneck around ~12 Gbps shared
across ports, rather than independent 25 Gbps per interface.
Question: Is this the current expected performance on T5000, or is additional
driver/kernel configuration required to reach full QSFP28 line rate?
- PLATFORM AND ENVIRONMENT
| Item | Details |
| Device | NVIDIA Jetson T5000 |
| Interfaces | QSFP28 optical ports: mgbe0_0, mgbe1_0, mgbe2_0, mgbe3_0 |
| OS | Ubuntu on Jetson (tegra-ubuntu) |
| Tool | iperf3 |
| Power/clocks | sudo nvpmodel -m 0 and sudo jetson_clocks on all test nodes |
| MGBE config | threaded mode enabled on mgbe0_0βmgbe3_0 (server and client) |
Network topology:
| Role | IP addresses | Notes |
| Server | 192.168.1.100β103 | One iperf3 -s instance per port |
| Client | 192.168.1.200β203 | One iperf3 -c instance per port |
Each client stream is bound to its own source IP and targets the matching server
IP/port (1:1 mapping across four links).
- TEST PROCEDURE
3.1 Server side (192.168.1.100 β 103)
sudo nvpmodel -m 0
sudo jetson_clocks
echo 1 > /sys/devices/platform/bus@0/a808a10000.ethernet/net/mgbe0_0/threaded
echo 1 > /sys/devices/platform/bus@0/a808b10000.ethernet/net/mgbe1_0/threaded
echo 1 > /sys/devices/platform/bus@0/a808d10000.ethernet/net/mgbe2_0/threaded
echo 1 > /sys/devices/platform/bus@0/a808e10000.ethernet/net/mgbe3_0/threaded
iperf3 -s -B 192.168.1.100 -p 5010 &
iperf3 -s -B 192.168.1.101 -p 5011 &
iperf3 -s -B 192.168.1.102 -p 5012 &
iperf3 -s -B 192.168.1.103 -p 5013 &
3.2 Client side (192.168.1.200 β 203)
sudo nvpmodel -m 0
sudo jetson_clocks
iperf3 -c 192.168.1.100 -B 192.168.1.200 -i 1 -t 300 -p 5010
iperf3 -c 192.168.1.101 -B 192.168.1.201 -i 1 -t 300 -p 5011
iperf3 -c 192.168.1.102 -B 192.168.1.202 -i 1 -t 300 -p 5012
iperf3 -c 192.168.1.103 -B 192.168.1.203 -i 1 -t 300 -p 5013
3.3 MGBE threaded mode (configured and enabled on all test nodes)
Note: The above threaded mode was applied on both server and client sides before
running iperf3. Throughput results in Section 4 were obtained with this
configuration already in place.
- TEST RESULTS
4.1 Single stream (baseline)
Command:
iperf3 -c 192.168.1.100 -B 192.168.1.200 -i 1 -t 30 -p 5010
Result:
Connecting to host 192.168.1.100, port 5010
[ 5] local 192.168.1.200 port 54357 connected to 192.168.1.100 port 5010
[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.00 sec 1.21 GBytes 10.4 Gbits/sec 124 794 KBytes
[ 5] 1.00-2.00 sec 1.47 GBytes 12.7 Gbits/sec 21 1.14 MBytes
[ 5] 2.00-3.00 sec 1.48 GBytes 12.7 Gbits/sec 1 1.46 MBytes
β¦
[ 5] 29.00-30.00 sec 1.48 GBytes 12.7 Gbits/sec 0 1.72 MBytes
[ 5] 0.00-30.00 sec 44.0 GBytes 12.6 Gbits/sec 162 sender
[ 5] 0.00-30.00 sec 44.0 GBytes 12.6 Gbits/sec receiver
iperf Done.
Summary:
- Steady-state throughput: ~12.7 Gbits/sec after TCP slow start
- Total retransmissions: 162 over 30 seconds (124 in the first second)
4.2 Four simultaneous streams
When all four client/server pairs run in parallel, each stream averages only
~3 Gbps, with highly variable per-second rates. Several runs showed 0.00
bits/sec on the receiver summary line (tests interrupted with Ctrl-C).
| Stream (client β server) | Duration | Avg throughput (sender) |
| 192.168.1.200 β .100 (port 5010) | ~262 s | 3.32 Gbits/sec |
| 192.168.1.201 β .101 (port 5011) | ~256 s | 3.45 Gbits/sec |
| 192.168.1.202 β .102 (port 5012) | ~248 s | 2.78 Gbits/sec |
| 192.168.1.203 β .103 (port 5013) | ~223 s | 3.09 Gbits/sec |
Observation: Total aggregate throughput across 4 links is approximately
~12 Gbps, consistent with a shared bottleneck rather than 4 x 25 Gbps.
Example excerpt (stream 1, interrupted):
[ 5] 258.00-259.00 sec 417 MBytes 3.50 Gbits/sec 0 2.06 MBytes
[ 5] 259.00-260.00 sec 572 MBytes 4.80 Gbits/sec 0 2.06 MBytes
[ 5] 260.00-261.00 sec 754 MBytes 6.32 Gbits/sec 0 2.06 MBytes
[ 5] 261.00-262.00 sec 1.34 GBytes 11.5 Gbits/sec 2 2.06 MBytes
[ 5] 0.00-262.09 sec 101 GBytes 3.32 Gbits/sec 28 sender
[ 5] 0.00-262.09 sec 0.00 Bytes 0.00 bits/sec receiver
iperf3: interrupt - the client has terminated
- ADDITIONAL TESTS (NO IMPROVEMENT)
The following were also tried without meaningful improvement (MGBE threaded
mode was already enabled during all tests above):
- Changing iperf3 parallel stream count (-P)
- UDP tests
- Setting target bitrate with -b 25G
None of these raised throughput above the ~12 Gbps ceiling (single stream) or
~12 Gbps aggregate (four streams).
- LINK-LAYER OBSERVATIONS (OPTIONAL)
On client interface mgbe0_0, ethtool -S showed non-zero receive error counters
during testing, for example:
mmc_rx_crc_error: 125
mmc_rx_packet_smd_err_cnt: 158606
TCP retransmission count (162 over 30 s in single-stream test) may correlate
with physical-layer receive errors. Full ethtool output can be provided on
request.
QUESTIONS FOR NVIDIA
Is ~12.7 Gbps per MGBE port (TCP, single stream) the current expected
maximum on Jetson T5000, or should we expect near 25 Gbps per QSFP28 link? -
When using all four MGBE ports concurrently, should each port achieve
independent line rate, or is there a known platform/DMA/PCIe aggregate
bandwidth limit around ~12 Gbps? -
Are there recommended kernel/driver tunings for MGBE on T5000 (e.g.
threaded sysfs, IRQ affinity, ring buffer sizes, MTU, firmware settings) to
reach full QSFP28 performance? -
Could retransmissions / link-layer errors limit TCP throughput in this
setup, and what ethtool -S / debug steps do you recommend?
END OF DOCUMENT
