JETSON Thor T5000 MODULE_SLEEP_N
Hi Nvidia
When Thor enters Suspend mode under the system, will MODULE_SLEEP_N change from H to L?
Or is it that MODULE_SLEEP_N is merely an input, where pulling MODULE_SLEEP_N low externally will put Thor into Suspend mode, but during system-level Suspend, MODULE_SLEEP_N remains high?
MODULE_SPEEP_N indicates the system’s power state. It is high in Normal mode and low when the system enters Sleep mode. Therefore, it is an output status signal, not an input used to trigger Suspend mode.
Thank you,
