HI team,
I am designing the power section for jeston Thor T5000. What would be the ideal current consumption of the SYS_VIN_HV rail assuming the voltage is 12V (as recommended in the datasheet 6.1.1 section). How do i consider it ?
I= 130W/12V gives 10.83 A. Should i consider this with some extra margin as the output current capability of the Voltage regulator IC powering the SYS_VIN_HV rail ?
Please let me know.
Note, the Jetson Thor Series Modules Data Sheet v1.5 released yesterday.
Use the 22A Imax at 20V from Table 6-2 Absolute Max Ratings for the calculation for SYS_VIN_HV on T5000: 22A*20V=440W → 440W/12V=~36.7A.
Adding extra margin on top of this value is a good idea.
