Environment:
- Board: Jetson Thor custom DV sample
- Jetson Linux kernel: 6.8.12-rt-tegra #1 SMP PREEMPT_RT
- Kernel build date: Aug 6, 2026
- Device tree compatible: cowa,cowa+p3834-0000
- UART: ttyAMA10
- UART MMIO: 0x810c540000
- IRQ: 72
- PL011 peripheral ID: 0x00051011
- GPCDMA RX channel: CH12
- GPCDMA TX channel: CH22
- GPCDMA/SMMU stream ID: 0x80c
- Baud rate: 115200
Issue:
During a long-duration DV test, the system repeatedly panics and reboots.
The capture lasted approximately 6 days 21 hours and recorded 8 kernel panics.
All panics occur in the PL011 RX DMA receive path:
__memcpy
pl011_dma_rx_chars
pl011_dma_rx_irq
or:
__memcpy
pl011_dma_rx_chars
pl011_dma_rx_callback
vchan_complete
Six crashes run in irq/72-uart-pl0 and two run in irq/139-gpcdma.
Typical errors before the panic include:
- tegra-gpcdma: cookie is not found
- GPCDMA CH12 mc slave error
- arm-smmu-v3 event 0x10
- tegra-mc: gpcdmaw non-secure write … EMEM address decode error
- Unable to handle kernel paging request at virtual address ffff8000…
The invalid address is used as the source of a 0x700-byte memcpy in
pl011_dma_rx_chars(). The PTE for the address is empty.
The UART is used by an IMU614 module through /dev/ttyAMA10. However, we have not yet proven that the user-space IMU test is the sole trigger. The same UART/DMA path remains enabled in the device tree.
Questions:
Is this a known PL011/GPCDMA issue on Jetson Thor?
Is the RX/TX DMA configuration below correct for UART10?
dmas = <&gpcdma 12 12 TEGRA264_GPCDMA_SID_UART10>,
<&gpcdma 12 22 TEGRA264_GPCDMA_SID_UART10>;
dma-names = “rx”, “tx”;
iommus = <&smmu1_mmu TEGRA264_GPCDMA_SID_UART10>; -
Should dmaengine_terminate_sync() or dmaengine_synchronize() be used before freeing the PL011 RX DMA buffers?
Is there a known fix for a possible race between pl011_dma_rx_callback(), UART IRQ handling, and pl011_dma_shutdown()?
Could the NVIDIA MMIS register mapping in amba-pl011.c be incorrect?
Is this fixed in a newer Jetson Linux/JetPack release?
We can provide:
- Full serial console log
- Full dmesg
- Runtime extracted device tree
- Kernel config
- Relevant kernel source
